GenerateDirectionsFeatures
Summary
Creates a feature class of route lines on the map and corresponding text directions generated by solving a network analysis layer. The output can be modified using the StreetDirectionProperties object of the network analysis layer.
Discussion
Several Network Analyst solvers produce on-street routes as output and offer the option to create turn-by-turn text directions describing those routes. GenerateDirectionsFeatures allows you to produce those text directions as a feature class that pairs each piece of the text direction with a corresponding line feature on the map.
You can modify the output of the directions, such as the language, style, and units, using the StreetDirectionProperties settings on the network analysis layer.
The GenerateDirectionsFeatures function only works with route, vehicle routing problem, and closest facility network analysis layers. Additionally, the network dataset used by the analysis layer must be configured for directions.
Syntax
GenerateDirectionsFeatures(network_analyst_layer, {catalog_path}, {schema_only}, {configuration_keyword})
Parameter Explanation Data Type
A network analysis layer object or layer name.
The analysis layer solver type must be route, vehicle routing problem, or closest facility because directions support is required. The network dataset used by the analysis layer must be configured for directions.
Caution:
This function does not support last mile delivery or waste collection analysis layers even though these layer types support directions.
Layer
catalog_path
The catalog path to the output directions feature class.
The default value is in_memory\Directions.
String
schema_only
Specifies whether an empty directions feature class will be generated or if it will be populated with direction features.
The default value is False.
Boolean
The configuration keyword of the output directions feature class.
The default value is None.
String
Return value
Data Type Explanation
String
Code sample
GenerateDirectionsFeatures example (workflow)
Get a route layer object and generate directions from it.
#Get the route layer object from a layer named "Route" in the map
doc = arcpy.mp.ArcGISProject('current')
map_obj = doc.listMaps()[0]
rt_layer = map_obj.listLayers('Route')[0]
#Generate directions features and save them to disk.
arcpy.na.GenerateDirectionsFeatures(rt_layer,
                                    'C:/Data/Directions.gdb/RouteDirections')
