LastMileDeliveryInputDataType
Summary
Enumeration of input types for the LastMileDelivery solver.
Properties
Name Explanation Data type
Orders
(Read only)
The orders that will be used as input for the Last Mile Delivery analysis. These are the final customer locations where the routes deliver the packages or initial customer location where they are picking up packages for shipment.
Object
Depots
(Read only)
The depots that will be used as input for the Last Mile Delivery analysis. A depot is a location that a vehicle departs from at the beginning of its workday and returns to at the end of the workday.
Object
Routes
(Read only)
The routes that will be used as input for the Last Mile Delivery analysis. A route defines vehicle and driver characteristics.
Object
Breaks
(Read only)
The breaks that will be used as input for the Last Mile Delivery analysis. These model driver rest periods, such as lunch and bathroom breaks.
Object
OrderSpecialties
(Read only)
The specialties that are required by orders. A route can service an order only if it supports all the specialties required for that order. For example, an order may require a technician with a certain skill set or a vehicle with certain capabilities.
Object
RouteSpecialties
(Read only)
The specialties that are supported by routes. A route can service an order only if the route supports all the specialties required for that order. For example, an order may require a technician with a certain skill set or a vehicle with certain capabilities.
Object
Zones
(Read only)
The route zones that will be used as input for the analysis. A zone is a polygon that delineates work territories for given routes and is used to constrain routes to servicing only those orders that are within or near the specified area.
Object
PointBarriers
(Read only)
Point barriers that temporarily restrict traversal across or add impedance to points on the network.
Object
LineBarriers
(Read only)
Line barriers that temporarily restrict traversal across a line.
Object
PolygonBarriers
(Read only)
Polygon barriers that temporarily restrict traversal or scale impedance on the parts of the network they cover.
Object
