ListDirectionsLanguages
Summary
Returns a list of the languages in which you can generate directions for the routes you create during network analysis.
Syntax
ListDirectionsLanguages({network_dataset_path})
Parameter Explanation Data Type
This parameter is deprecated. Any value entered will be ignored.
String
Return value
Data Type Explanation
String
A list of two- and five-character strings representing the languages available for generating directions. Learn more about directions language codes.
Code sample
ListDirectionsLanguages example
Reads the available languages and stores them in a variable.
import arcpy
# Create a list of directions languages available with your ArcGIS installation
languages = arcpy.na.ListDirectionsLanguages()
