ListDirectionsStyleNames
Summary
Returns a list of the available styles for generating directions from a route created during network analysis. Each directions style is appropriate for a different application.
Discussion
This function can be used in a custom script tool validation to populate a ValueList of available directions styles for the user to choose from.
Syntax
ListDirectionsStyleNames({network_dataset_path})
Parameter Explanation Data Type
A variable that references the catalog path of the network dataset. The catalog path of a network dataset can be obtained from the dataSource property of a network dataset layer or a network analysis layer object. It can also be obtained from the catalogPath property of a network dataset describe object.
The parameter also accepts a network dataset layer object.
String
Return value
Data Type Explanation
String
The list of available directions styles containing strings representing the styles installed on your machine. It is a subset of the following styles:
  • NA Desktop—This style generates turn-by-turn directions suitable for printing.
  • NA Navigation—This style generates turn-by-turn directions designed for an in-vehicle navigation device.
  • NA Campus—This style generates turn-by-turn directions suitable for indoor and outdoor pedestrian routing.
Code sample
ListDirectionsStyleNames example
Lists supported directions styles.
# Create a list of available directions styles
dir_styles = arcpy.na.ListDirectionsStyleNames()
