LocationAllocation input data types
The input data types that can be specified when performing a location-allocation analysis are described below.
Facilities
Specify one or more facilities that the solver will choose from during the analysis. The solver identifies the best facilities to allocate demand in the most efficient way according to the problem type and criteria you specify.
The data type supports the following fields:
Field |
Description |
Data type |
The name of the facility. The name is included in the name of output allocation lines if the facility is part of the solution. |
Text |
Specifies whether the facility is a candidate, required, or a competitor facility. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
Long |
The relative weighting of the facility, which is used to rate the attractiveness, desirability, or bias of one facility compared to another. For example, a value of 2.0 may capture the preference of customers who prefer, at a ratio of 2 to 1, shopping in one facility over another facility. Factors that potentially affect facility weight include square footage, neighborhood, and age of the building. Weight values other than one are only honored by the maximize market share and target market share problem types; they are ignored in other problem types. |
Double |
The Capacity specifies how much weighted demand the facility is capable of supplying. Excess demand won't be allocated to a facility even if that demand is within the facility's default measurement cutoff. Any value assigned to the |
Double |
Specifies the direction a vehicle may arrive at or depart from the facility. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
The |
Long |
The direction in which a point is moving. The units are degrees and are measured clockwise from true north. This field is used in conjunction with the Bearing data is usually sent automatically from a mobile device equipped with a GPS receiver. Try to include bearing data if you are loading an input location that is moving, such as a pedestrian or a vehicle. Using this field tends to prevent adding locations to the wrong edges, which can occur when a vehicle is near an intersection or an overpass, for example. Bearing also helps the tool determine on which side of the street the point is. |
Double |
The bearing tolerance value creates a range of acceptable bearing values when locating moving points on an edge using the The units are in degrees, and the default value is 30. Values must be greater than 0 and less than 180. A value of 30 means that when Network Analyst attempts to add a network location on an edge, a range of acceptable bearing values is generated 15 degrees to either side of the edge (left and right) and in both digitized directions of the edge. |
Double |
This field is only used in the solve process if the The units of |
Double |
Network location fields
Together, these properties describe the point on the network where the object is located. |
DemandPoints
Specify one or more demand points. The solver identifies the best facilities based in large part on how they serve the demand points specified here.
A demand point is typically a location that represents the people or things requiring the goods and services your facilities provide. A demand point may be a ZIP Code centroid weighted by the number of people residing within it or by the expected consumption generated by those people. Demand points can also represent business customers. If you supply businesses with a high turnover of inventory, they will be weighted more heavily than those with a low turnover rate.
Field |
Description |
Data type |
The name of the demand point. The name is included in the name of the output allocation line or lines if the demand point is part of the solution. |
Text |
The name of the group to which the demand point belongs. This field is ignored for the Maximize Capacitated Coverage, Target Market Share, and Maximize Market Share problem types. If demand points share a group name, the solver allocates all members of the group to the same facility. (If constraints, such as a cutoff distance, prevent any of the demand points in the group from reaching the same facility, none of the demand points are allocated.) |
Text |
The relative weighting of the demand point. A value of 2.0 means the demand point is twice as important as one with a weight of 1.0. If demand points represent households, for example, weight can indicate the number of people in each household. |
Double |
The impedance value at which to stop searching for demand points from a given facility. The demand point can't be allocated to a facility that is beyond the value indicated here. This attribute allows you to specify a cutoff value for each demand point. For example, you may find that people in rural areas are willing to travel up to 10 miles to reach a facility, while those in urban areas are only willing to travel up to 2 miles. You can model this behavior by setting the A value for this attribute overrides the default set for the analysis using the If the travel mode set for the analysis uses a time-based impedance attribute, the values are interpreted to be in the units specified by the The default value is |
Double |
Allows you to override the default value set for the analysis by the |
Long |
Double |
Specifies the direction a vehicle may arrive at or depart from the demand point. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
The |
Long |
Double |
Double |
Double |
PointBarriers
Use this parameter to specify one or more points that will act as temporary restrictions or represent additional time or distance that may be required to travel on the underlying streets. For example, a point barrier can be used to represent a fallen tree along a street or a time delay spent at a railroad crossing.
Field |
Description |
Data type |
The name of the barrier. |
Text |
Specifies whether the point barrier restricts travel completely or adds time or distance when it is crossed. The value for this attribute is specified as one of the following integers (use the numeric code, not the name in parentheses):
Long |
The added travel time when the barrier is traversed. This field value must be greater than or equal to zero, and the values are interpreted to be in the units specified by the |
Double |
The added distance when the barrier is traversed. This field value must be greater than or equal to zero, and the values are interpreted to be in the units specified by the |
Double |
The added cost when the barrier is traversed. This field value must be greater than or equal to zero, and the values are interpreted to be in unknown units. |
Double |
Specifies how the restriction point barriers are applied to the edge elements during the analysis. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
Long |
Specifies the direction of traffic that is affected by the barrier. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
Because junctions are points and don't have a side, barriers on junctions affect all vehicles regardless of the curb approach. The |
Long |
Double |
Double |
Double |
LineBarriers
Use this parameter to specify one or more lines that prohibit travel anywhere the lines intersect the streets. For example, a parade or protest that blocks traffic across several street segments can be modeled with a line barrier. A line barrier can also quickly fence off several roads from being traversed, thereby channeling possible routes away from undesirable parts of the street network.
Field |
Description |
Data type |
Text |
Specifies whether the barrier restricts travel completely or scales the cost (such as time or distance) for traveling through it. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
Long |
This is the factor by which the travel time of the streets intersected by the barrier is multiplied. The field value must be greater than zero. |
Double |
This is the factor by which the distance of the streets intersected by the barrier is multiplied. The field value must be greater than zero. |
Double |
This is the factor by which the cost of the streets intersected by the barrier is multiplied. The field value must be greater than zero. |
Double |
The information in this field defines which network edges and junctions are covered by the line or polygon and the portion of each edge element that is covered. You cannot directly read or edit the information contained in this field, but Network Analyst interprets it when solving an analysis. |
BLOB |
PolygonBarriers
Use this parameter to specify polygons that either completely restrict travel or proportionately scale the time or distance required to travel on the streets intersected by the polygons.
Field |
Description |
Data type |
Text |
Long |
Double |
Double |
Double |
BLOB |
