NAClassFieldMappings
Summary
Provides a dictionary of NAClassFieldMap objects that are used to map field names or set default values for the properties of a network analysis class within a network analysis layer. The dictionary keys are the network analysis class property names, and the values are the NAClassFieldMap objects.
Discussion
The NAClassFieldMappings object or its string representation is used as input to the field_mappings parameter in the Add Locations tool. The NAClassFieldMap objects contained within the NAClassFieldMappings object provide access to get or set the default value and the mapped field name associated with each property of the network analysis class.
Syntax
NAClassFieldMappings(network_analyst_layer, sub_layer_name, {use_location_fields}, {list_candidate_fields})
| Name | Explanation | Data type |
network_analyst_layer |
A variable that references a |
Layer |
sub_layer_name |
The sublayer name for which the field mappings are to be created. The name must be valid for the particular network analysis layer type. For a given network analysis layer, the sublayer name can be determined using the |
String |
use_location_fields (Optional) |
Specifies whether to create the field mappings for the network location properties along with other properties. The default value is False. |
Boolean |
list_candidate_fields (Optional) |
A list of The default value is None. |
Field |
Code sample
The following script shows how to load fire stations as facilities into an existing service area layer and specify a delay of 10 minutes when loading the facilities using the NAClassFieldMappings object. It assumes that a service area network analysis layer named Fire Stations Coverage, created from the tutorial network dataset for the San Francisco region, and a feature layer named FireStations are already added to an existing map document.
#Get the service area layer called "Fire Stations Coverage" from the map
doc = arcpy.mp.ArcGISProject('current')
map_obj = doc.listMaps()[0]
sa_layer = map_obj.listLayers("Fire Stations Coverage")[0]
#Get the list of fields from the FireStations feature layer in the map
fields = arcpy.ListFields("FireStations")
#Get the facilities sublayer name from the service area layer. Note that we are
#not using a string called "Facilities" because the sublayer name can be
#different if using ArcGIS on a non-English operating system.
facilities_sublayer_name = arcpy.na.GetNAClassNames(sa_layer)["Facilities"]
#Create a field mappings object for facilities sublayer based on the fields from
#FireStations layer
field_mappings = arcpy.na.NAClassFieldMappings(sa_layer,
facilities_sublayer_name, False, fields)
#Get the field map corresponding to the "Attr_TravelTime" property of facilities
field_map = field_mappings["Attr_TravelTime"]
#Set a delay of 10 minutes for the facilities
field_map.defaultValue = 10
#Load the fire stations as service area facilities using the field mappings
arcpy.na.AddLocations(sa_layer, facilities_sublayer_name, "FireStations",
field_mappings)
The example shows how to find the best route between some store locations, considering weather conditions as slowdown areas. It illustrates how to use the NAClassFieldMappings object while loading the weather polygons as polygon barriers and store locations as stops using the Add Locations tool.
# Name: NAClassFieldMappings_workflow_01.py
# Description: Find the fastest route to visit several stores when part of the
# road network has been slowed due to bad weather. Use
# NAClassFieldMappings to map fields from the input data and to
# set default values for some parameters.
# Requirements: Network Analyst extension
#Import system modules
import arcpy
from arcpy import env
import os
try:
#Set environment settings
output_dir = "C:/Data"
#The NA layer's data will be saved to the workspace specified here
env.workspace = os.path.join(output_dir, "Output.gdb")
env.overwriteOutput = True
#Set local variables
input_gdb = "C:/Data/SanFrancisco.gdb"
network = os.path.join(input_gdb, "Transportation", "Streets_ND")
polygon_barriers = os.path.join(input_gdb, "Analysis",
"WeatherSlowDownAreas")
stops = os.path.join(input_gdb, "Analysis", "Stores")
travel_mode = "Driving Time"
layer_name = "WeatherRoute"
output_layer_file = os.path.join(output_dir, layer_name + ".lyrx")
#Create a new route layer
route_layer = arcpy.na.MakeRouteAnalysisLayer(network, layer_name,
travel_mode).getOutput(0)
#Get na class names based on the layer
na_classes = arcpy.na.GetNAClassNames(route_layer, "INPUT")
#Create field mappings for loading barriers as scaled cost polygon barriers
#with a slow down of 40%
field_mappings = arcpy.na.NAClassFieldMappings(route_layer,
na_classes["PolygonBarriers"])
field_mappings["BarrierType"].defaultValue = 1
#Figure out the layer's impedance attribute
solver_props = arcpy.na.GetSolverProperties(route_layer)
impedance = solver_props.impedance
field_mappings["Attr_" + impedance].defaultValue = 1.4
#Load weather polygons as slow down barriers
arcpy.na.AddLocations(route_layer, na_classes["PolygonBarriers"],
polygon_barriers, field_mappings)
#Get a list of field objects from the stores feature class
stores_fields = arcpy.ListFields(stops)
#Create field mappings for loading stops based on the field names from the
#stores
stops_field_mappings = arcpy.na.NAClassFieldMappings(route_layer,
na_classes["Stops"],
False, stores_fields)
#Load stops using the field mappings
arcpy.na.AddLocations(route_layer, na_classes["Stops"], stops,
stops_field_mappings)
#Solve the route
arcpy.na.Solve(route_layer)
#Save the solved service area layer as a layer file on disk
route_layer.saveACopy(output_layer_file)
print("Script completed successfully")
except Exception as e:
# If an error occurred, print line number and error message
import traceback, sys
tb = sys.exc_info()[2]
print("An error occured on line %i" % tb.tb_lineno)
print(str(e))
