OriginDestinationCostMatrix input data types
The input data types that can be specified when performing an origin-destination cost matrix analysis are described below.
Origins
Specifies the starting points from which to travel to the destinations.
The data type supports the following fields:
Field
Data type
Name
The name of the origin. The name can be a unique identifier for the origin. The name is included in the output lines (as the OriginName field) and in the output origins (as the Name field) and can be used to join additional information from the tool outputs to the attributes of your origins.
If the name is not specified, a unique name prefixed with Location is automatically generated.
Text
TargetDestinationCount
The maximum number of destinations to find for the origin.
This field allows you to specify a different number of destinations to find for each origin. For example, using this field, you can find the three closest destinations from one origin and the two closest destinations from another origin.
A value for this field overrides the default set for the analysis using the defaultDestinationCount property.
The default value is Null, which results in using the default value set by the defaultDestinationCount property for all the origins.
Long
Cutoff
The impedance value at which to stop searching for destinations from a given origin. This attribute allows you to specify a different cutoff value for each destination. For example, using this attribute, you can specify to search for destinations within five minutes of travel time from one origin and to search for destinations within eight minutes of travel time from another origin.
A value for this attribute overrides the default set for the analysis using the defaultImpedanceCutoff property.
If the travel mode in the analysis uses a time-based impedance attribute, the values are interpreted to be in the units specified by the timeUnits property. If the travel mode in the analysis uses a distance-based impedance attribute, the values are interpreted to be in the units specified by the distanceUnits property. If the travel mode in the analysis uses an impedance attribute that is neither time based nor distance based, the values are interpreted to be in unknown units.
The default value is Null, which results in using the default value set by the defaultImpedanceCutoff property for all the origins.
Double
CurbApproach
Specifies the direction a vehicle may depart from the origin. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
  • 0 (Either side of vehicle)—The vehicle can depart the origin in either direction, so a U-turn is allowed at the origin. This setting can be chosen if it is possible and practical for a vehicle to turn around at the origin. This decision may depend on the width of the road and the amount of traffic or whether the origin has a parking lot where vehicles can enter and turn around.
  • 1 (Right side of vehicle)—When the vehicle departs the origin, the origin must be on the right side of the vehicle. A U-turn is prohibited. This is typically used for vehicles such as buses that must depart from the bus stop on the right-hand side.
  • 2 (Left side of vehicle)—When the vehicle departs the origin, the curb must be on the left side of the vehicle. A U-turn is prohibited. This is typically used for vehicles such as buses that must depart from the bus stop on the left-hand side.
  • 3 (No U-Turn)—For this tool, this value functions the same as 0 (Either side of vehicle).
The CurbApproach attribute is designed to work with both kinds of national driving standards: right-hand traffic (United States) and left-hand traffic (United Kingdom). First, consider an origin on the left side of a vehicle. It is always on the left side regardless of whether the vehicle travels on the left or right half of the road. What may change with national driving standards is your decision to depart the origin from one of two directions, that is, so it ends up on the right or left side of the vehicle. For example, if you want to depart from an origin and not have a lane of traffic between the vehicle and the origin, choose 1 (Right side of vehicle) in the United States and 2 (Left side of vehicle) in the United Kingdom.
Long
Bearing
The direction in which a point is moving. The units are degrees and are measured clockwise from true north. This field is used in conjunction with the BearingTol field.
Bearing data is usually sent automatically from a mobile device equipped with a GPS receiver. Try to include bearing data if you are loading an input location that is moving, such as a pedestrian or a vehicle.
Using this field tends to prevent adding locations to the wrong edges, which can occur when a vehicle is near an intersection or an overpass, for example. Bearing also helps the tool determine on which side of the street the point is.
Learn more about bearing and bearing tolerance
Double
BearingTol
The bearing tolerance value creates a range of acceptable bearing values when locating moving points on an edge using the Bearing field. If the Bearing field value is within the range of acceptable values that are generated from the bearing tolerance on an edge, the point can be added as a network location there; otherwise, the closest point on the next-nearest edge is evaluated.
The units are in degrees, and the default value is 30. Values must be greater than 0 and less than 180. A value of 30 means that when Network Analyst attempts to add a network location on an edge, a range of acceptable bearing values is generated 15 degrees to either side of the edge (left and right) and in both digitized directions of the edge.
Double
NavLatency
This field is only used in the solve process if the Bearing and BearingTol fields also have values; however, entering a NavLatency field value is optional, even when values are present in Bearing and BearingTol. NavLatency indicates how much cost is expected to elapse from the moment GPS information is sent from a moving vehicle to a server and the moment the processed route is received by the vehicle's navigation device.
The units of NavLatency are the same as the units of the impedance attribute.
Double
Network location fields
  • SourceID
  • SourceOID
  • PosAlong
  • SideOfEdge
Together, these properties describe the point on the network where the object is located.
Learn more about locating inputs on a network
Destinations
Specifies the ending point locations to travel to from the origins.
Field
Data type
Name
The name of the destination. The name can be a unique identifier for the destination. The name is included in the output lines (as the DestinationName field) and in the output destinations (as the Name field) and can be used to join additional information from the tool outputs to the attributes of your destinations.
Text
CurbApproach
Specifies the direction a vehicle may arrive at a destination. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
  • 0 (Either side of vehicle)—The vehicle can arrive at the destination in either direction, so a U-turn is allowed at the origin. This setting can be chosen if it is possible and practical for a vehicle to turn around at the destination. This decision may depend on the width of the road and the amount of traffic or whether the destination has a parking lot where vehicles can enter and turn around.
  • 1 ( Right side of vehicle)—When the vehicle arrive at the destination, the destination must be on the right side of the vehicle. A U-turn is prohibited. This is typically used for vehicles such as buses that must depart from the bus stop on the right-hand side.
  • 2 (Left side of vehicle)—When the vehicle arrives at the destination, the curb must be on the left side of the vehicle. A U-turn is prohibited. This is typically used for vehicles such as buses that must depart from the bus stop on the left-hand side.
Long
Bearing
Double
BearingTol
Double
NavLatency
Double
  • SourceID
  • SourceOID
  • PosAlong
  • SideOfEdge
PointBarriers
Use this parameter to specify one or more points that will act as temporary restrictions or represent additional time or distance that may be required to travel on the underlying streets. For example, a point barrier can be used to represent a fallen tree along a street or a time delay spent at a railroad crossing.
Field
Data type
Name
The name of the barrier.
Text
BarrierType
Specifies whether the point barrier restricts travel completely or adds time or distance when it is crossed. The value for this attribute is specified as one of the following integers (use the numeric code, not the name in parentheses):
  • 0 (Restriction)—Prohibits travel through the barrier. The barrier is referred to as a restriction point barrier since it acts as a restriction.
  • 2 (Added Cost)—Traveling through the barrier increases the travel time or distance by the amount specified in the Additional_Time, Additional_Distance, or AdditionalCost field. This barrier type is referred to as an added cost point barrier.
Long
Additional_Time
The added travel time when the barrier is traversed.
This field value must be greater than or equal to zero, and the values are interpreted to be in the units specified by the timeUnits property.
Double
Additional_Distance
The added distance when the barrier is traversed.
This field value must be greater than or equal to zero, and the values are interpreted to be in the units specified by the distanceUnits property.
Double
AdditionalCost
The added cost when the barrier is traversed.
This field value must be greater than or equal to zero, and the values are interpreted to be in unknown units.
Double
FullEdge
Specifies how the restriction point barriers are applied to the edge elements during the analysis. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
  • 0 (False)—Permits travel on the edge up to the barrier but not through it. This is the default value.
  • 1 (True)—Restricts travel anywhere on the associated edge.
Long
CurbApproach
Specifies the direction of traffic that is affected by the barrier. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
  • 0 (Either side of vehicle)—The barrier affects travel over the edge in both directions.
  • 1 (Right side of vehicle)—Vehicles are only affected if the barrier is on their right side during the approach. Vehicles that traverse the same edge but approach the barrier on their left side are not affected by the barrier.
  • 2 (Left side of vehicle)—Vehicles are only affected if the barrier is on their left side during the approach. Vehicles that traverse the same edge but approach the barrier on their right side are not affected by the barrier.
Because junctions are points and don't have a side, barriers on junctions affect all vehicles regardless of the curb approach.
The CurbApproach attribute works with both types of national driving standards: right-hand traffic (United States) and left-hand traffic (United Kingdom). First, consider a facility on the left side of a vehicle. It is always on the left side regardless of whether the vehicle travels on the left or right half of the road. What may change with national driving standards is your decision to approach a facility from one of two directions, that is, so it ends up on the right or left side of the vehicle. For example, to arrive at a facility and not have a lane of traffic between the vehicle and the facility, choose 1 (Right side of vehicle) in the United States and 2 (Left side of vehicle) in the United Kingdom.
Long
Bearing
Double
BearingTol
Double
NavLatency
Double
  • SourceID
  • SourceOID
  • PosAlong
  • SideOfEdge
LineBarriers
Use this parameter to specify one or more lines that prohibit travel anywhere the lines intersect the streets. For example, a parade or protest that blocks traffic across several street segments can be modeled with a line barrier. A line barrier can also quickly fence off several roads from being traversed, thereby channeling possible routes away from undesirable parts of the street network.
Field
Data type
Name
Text
BarrierType
Specifies whether the barrier restricts travel completely or scales the cost (such as time or distance) for traveling through it. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
  • 0 (Restriction)—Prohibits travel anywhere the barrier intersects the transportation network. The barrier is referred to as a restriction line barrier.
  • 1 (Scaled Cost)—Scales the cost (such as travel time or distance) required to travel the underlying streets by a factor specified using the ScaledTimeFactor or ScaledDistanceFactor field. If the streets are partially covered by the barrier, the travel time or distance is apportioned and then scaled. For example, a factor of 0.25 means that travel on underlying streets is expected to be four times faster than normal. A factor of 3.0 means it is expected to take three times longer than normal to travel on underlying streets. This barrier type is referred to as a scaled-cost line barrier. It can be used to model slowdowns due to closure of traffic lanes during construction, for example.
Long
ScaledTimeFactor
This is the factor by which the travel time of the streets intersected by the barrier is multiplied. The field value must be greater than zero.
Double
This is the factor by which the distance of the streets intersected by the barrier is multiplied. The field value must be greater than zero.
Double
ScaledCostFactor
This is the factor by which the cost of the streets intersected by the barrier is multiplied. The field value must be greater than zero.
Double
Locations
The information in this field defines which network edges and junctions are covered by the line or polygon and the portion of each edge element that is covered. You cannot directly read or edit the information contained in this field, but Network Analyst interprets it when solving an analysis.
BLOB
PolygonBarriers
Use this parameter to specify polygons that either completely restrict travel or proportionately scale the time or distance required to travel on the streets intersected by the polygons.
Field
Data type
Name
Text
BarrierType
  • 0 (Restriction)—Prohibits traveling through any part of the barrier. The barrier is referred to as a restriction polygon barrier since it prohibits traveling on streets intersected by the barrier. One use of this type of barrier is to model floods covering areas of the street that make traveling on those streets impossible.
  • 1 (Scaled Cost)—Scales the cost (such as travel time or distance) required to travel the underlying streets by a factor specified using the ScaledTimeFactor or ScaledDistanceFactor field. If the streets are partially covered by the barrier, the travel time or distance is apportioned and then scaled. For example, a factor of 0.25 means that travel on underlying streets is expected to be four times faster than normal. A factor of 3.0 means it is expected to take three times longer than normal to travel on underlying streets. This barrier type is referred to as a scaled-cost polygon barrier. It can be used to model storms that reduce travel speeds in specific regions, for example.
Long
ScaledTimeFactor
Double
Double
ScaledCostFactor
Double
Locations
BLOB
