Route input data types
The input data types that can be specified when performing a route analysis are described below.
Stops
Specifies the locations the output route or routes will visit.
The data type supports the following fields:
Field |
Description |
Data type |
The name of the stop. The name is used in the driving directions. If no name is provided, a unique name prefixed with Location is automatically generated in the output stops, routes, and directions. |
Text |
The name of the route to which the stop belongs. Stops with the same Using this field, you can group stops into different routes, and the output attempts to generate one route for each group of stops.
Text |
The output routes will visit the stops in the order you specify with this attribute. In a group of stops that have the same If the |
Long |
The amount of time spent at the stop, which is added to the total time of the route. The default value is 0. The units for this attribute value are specified by the You can account for the extra time it takes at the stop to complete a task, such as to repair an appliance, deliver a package, or inspect the premises. |
Double |
The extra distance traveled at the stops, which is added to the total distance of the route. The default value is 0. The units for this attribute value are specified by the Generally, the location of a stop, such as a home, isn't exactly on the street; it is set back somewhat from the road. This attribute value can be used to model the distance between the actual stop location and its location on the street if it is important to include that distance in the total travel distance. |
Double |
The extra cost spent at the stop, which is added to the total cost of the route. The default value is 0. This attribute value should be used when the travel mode for the analysis uses an impedance attribute that is neither time based nor distance based. The units for the attribute values are interpreted to be in unknown units. |
Double |
The earliest time the stop can be visited. By specifying a start and end time for a stop's time window, you are defining when a route will visit the stop. When the travel mode for the analysis uses an impedance attribute that is time based, specifying time-window values will cause the analysis to find a solution that minimizes overall travel and reaches the stop within the prescribed time window. The value for this attribute should be a date and time value and can be specified using a This field can contain a null value; a null value indicates a route can arrive at any time before the time indicated in the |
Date |
The latest time the stop can be visited. By specifying a start and end time for a stop's time window, you are defining when a route will visit the stop. When the travel mode for the analysis uses an impedance attribute that is time based, specifying time-window values will cause the analysis to find a solution that minimizes overall travel and reaches the stop within the prescribed time window. The value for this attribute should be a date and time value and can be specified using a This field can contain a null value; a null value indicates a route can arrive at any time after the time indicated in the |
Date |
Specifies the direction a vehicle can arrive at and depart from the stop. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
The |
Long |
Specifies the stop type. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
Long |
The direction in which a point is moving. The units are degrees and are measured clockwise from true north. This field is used in conjunction with the Bearing data is usually sent automatically from a mobile device equipped with a GPS receiver. Try to include bearing data if you are loading an input location that is moving, such as a pedestrian or a vehicle. Using this field tends to prevent adding locations to the wrong edges, which can occur when a vehicle is near an intersection or an overpass, for example. Bearing also helps the tool determine on which side of the street the point is. |
Double |
The bearing tolerance value creates a range of acceptable bearing values when locating moving points on an edge using the The units are in degrees, and the default value is 30. Values must be greater than 0 and less than 180. A value of 30 means that when Network Analyst attempts to add a network location on an edge, a range of acceptable bearing values is generated 15 degrees to either side of the edge (left and right) and in both digitized directions of the edge. |
Double |
This field is only used in the solve process if the The units of The time units of |
Double |
Network location fields
Together, these properties describe the point on the network where the object is located. |
PointBarriers
Use this parameter to specify one or more points that will act as temporary restrictions or represent additional time or distance that may be required to travel on the underlying streets. For example, a point barrier can be used to represent a fallen tree along a street or a time delay spent at a railroad crossing.
Field |
Description |
Data type |
The name of the barrier. |
Text |
Specifies whether the point barrier restricts travel completely or adds time or distance when it is crossed. The value for this attribute is specified as one of the following integers (use the numeric code, not the name in parentheses):
Long |
The added travel time when the barrier is traversed. This field value must be greater than or equal to zero, and the values are interpreted to be in the units specified by the |
Double |
The added distance when the barrier is traversed. This field value must be greater than or equal to zero, and the values are interpreted to be in the units specified by the |
Double |
The added cost when the barrier is traversed. This field value must be greater than or equal to zero, and the values are interpreted to be in unknown units. |
Double |
Specifies how the restriction point barriers are applied to the edge elements during the analysis. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
Long |
Specifies the direction of traffic that is affected by the barrier. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
Because junctions are points and don't have a side, barriers on junctions affect all vehicles regardless of the curb approach. The |
Long |
Double |
Double |
Double |
LineBarriers
Use this parameter to specify one or more lines that prohibit travel anywhere the lines intersect the streets. For example, a parade or protest that blocks traffic across several street segments can be modeled with a line barrier. A line barrier can also quickly fence off several roads from being traversed, thereby channeling possible routes away from undesirable parts of the street network.
Field |
Description |
Data type |
Text |
Specifies whether the barrier restricts travel completely or scales the cost (such as time or distance) for traveling through it. The field value is specified as one of the following integers (use the numeric code, not the name in parentheses):
Long |
This is the factor by which the travel time of the streets intersected by the barrier is multiplied. The field value must be greater than zero. |
Double |
This is the factor by which the distance of the streets intersected by the barrier is multiplied. The field value must be greater than zero. |
Double |
This is the factor by which the cost of the streets intersected by the barrier is multiplied. The field value must be greater than zero. |
Double |
The information in this field defines which network edges and junctions are covered by the line or polygon and the portion of each edge element that is covered. You cannot directly read or edit the information contained in this field, but Network Analyst interprets it when solving an analysis. |
BLOB |
PolygonBarriers
Use this parameter to specify polygons that either completely restrict travel or proportionately scale the time or distance required to travel on the streets intersected by the polygons.
Field |
Description |
Data type |
Text |
Long |
Double |
Double |
Double |
BLOB |
