WasteCollectionOutputDataType
Summary
Enumeration of output types for the WasteCollection solver.
Properties
| Name | Explanation | Data type |
Stops (Read only) |
The stops included in the waste collection analysis, including information about which route served each stop and the stop sequence along the route. |
Object |
Depots (Read only) |
The depots included in the waste collection analysis, including information about how the depots were located on the network. |
Object |
Renewals (Read only) |
The renewals included in the waste collection analysis, including information about how the renewals were located on the network. |
Object |
RenewalVisits (Read only) |
Each instance of a renewal being visited by a route, including the time of the visit and information about the amount of waste unloaded at the renewal. |
Object |
Routes (Read only) |
The output routes. The routes describe the region each route will operate, the amount of waste collected, and the travel time and distance. |
Object |
RouteLines (Read only) |
The output route lines describing the paths taken through the network to visit the stops. |
Object |
DirectionPoints (Read only) |
This is the output turn-by-turn directions for the routes calculated in the analysis, represented as point locations along the routes where specific direction events or maneuvers occur. |
Object |
DirectionLines (Read only) |
This is the output route lines calculated in the analysis sliced to represent each route segment between |
Object |
