TopoCliff
Summary
Defines a list of line feature classes of cliff locations.
Discussion
This object is used in the tool Topo To Raster.
All lines must be oriented so that the left-hand side of the line is on the low side of the cliff and the right hand side is the high side of the cliff.
To display the direction of the line sections, change the Symbology to the Arrow at End option. This will draw the line sections with an arrow symbol showing the line directions.
Syntax
TopoCliff(inFeatures)
Name Explanation Data type
inFeatures
The input feature datasets.
String
Properties
inFeatures
(Read and Write)
String
Code sample
TopoCliff example 1 (Python window)
Demonstrates how to create a TopoCliff class and use it in the TopoToRaster tool within the Python window.
import arcpy
from arcpy import env
from arcpy.sa import *
env.workspace = "C:/sapyexamples/data"
myTopoPtElev = TopoPointElevation([["spots.shp", "spot_meter"], ["spots2.shp", "elev"]])
myTopoContour = TopoContour([["contours.shp", "spot_meter"]])
myTopoBoundary = TopoBoundary(["boundary.shp"])
myTopoLake = TopoLake(["lakes.shp"])
myTopoSink = TopoSink([["sink1.shp", "elevation"], ["sink2.shp", "NONE"]])
myTopoStream = TopoStream(["streams.shp"])
myTopoCliff = TopoCliff(["cliff.shp"])
myTopoCoast = TopoCoast(["coast.shp"])
myTopoExclusion = TopoExclusion(["ignore.shp"])
outTopoToRaster1 = TopoToRaster([myTopoPtElev, myTopoContour, myTopoBoundary, myTopoLake, myTopoSink, myTopoStream, myTopoCliff, myTopoCoast, myTopoExclusion])
outTopoToRaster1.save("C:/sapyexamples/output/ttraster1")
TopoCliff example 2 (stand-alone script)
Interpolates a surface with TopoToRaster using the TopoCliff class as one of the input parameters.
# Name: TopoBoundary_Ex_02.py
# Description: Run TopoToRaster using all the supported objects.
# Requirements: Spatial Analyst extension
# Import system modules
import arcpy
# Set environment settings
# Create all the supported Objects
# Run TopoToRaster
outTopoToRaster = TopoToRaster([myTopoPtElev, myTopoContour, myTopoBoundary, myTopoLake, myTopoSink, myTopoStream])
# Save the output
outTopoToRaster.save("C:/sapyexamples/output/ttraster2")
