Authentication settings
System administrators can manage many ArcGIS Pro user application settings.
The settings below should be added under the Authentication element in the Pro.settingsConfig file. One set of AuthConnection elements is required for each authentication connection you want to manage.
Learn more about authentication options
AuthConnection
In the user interface, authentication connections are on the Authentication tab of the Options dialog box. Each AuthConnection element must include all the elements that correspond to connection properties on the Add Connection dialog box.
An example of this setting for the Microsoft Entra ID connection type is shown below.
<Authentication>
<AuthConnection isLocked="true">
<Name>ConnectionName</Name>
<Type>MicrosoftEntraID</Type>
<Environment>AzureGlobal</Environment>
<TenantID>example.domain.com</TenantID>
<ClientID>123456789</ClientID>
<Scopes>
<Scope>Scope1</Scope>
<Scope>Scope2</Scope>
</Scopes>
</AuthConnection>
</Authentication>
An example of this setting for the Custom connection type is shown below.
<Authentication>
<Type>Custom</Type>
<AuthorizationURL>example.domain.com/oauth2/authorize</AuthorizationURL>
<TokenURL>example.domain.com/oauth2/token</TokenURL>
<Scopes>
</Scopes>
</AuthConnection>
</Authentication>
Name
In the user interface, this property corresponds to the Connection Name text box on the Add Connection dialog box.
Possible values are valid connection names. Connection names are limited to 50 characters and cannot contain a backslash ( \ ).
An example of this setting is shown below.
Type
In the user interface, this property corresponds to the Type setting on the Add Connection dialog box.
Possible values are the following:
MicrosoftEntraID(Microsoft Entra ID)Custom
Environment
In the user interface, this property corresponds to the Azure Environment options on the Add Connection dialog box when the Type setting is Microsoft Entra ID.
AzureGlobal(Azure)AzureChina(Azure China)AzureUSGovt(Azure US Government)
TenantID
In the user interface, this property corresponds to the Microsoft Entra Domain text box on the Add Connection dialog box when the Type setting is Microsoft Entra ID.
Possible values are Microsoft Entra ID domain names.
ClientID
In the user interface, this property corresponds to the Client ID text box on the Add Connection dialog box.
Possible values are client IDs for ArcGIS Pro.
AuthorizationURL
In the user interface, this property corresponds to the Authorization URL text box on the Add Connection dialog box when the Type setting is Custom.
Possible values are URLs of the endpoints for obtaining authorization.
TokenURL
In the user interface, this property corresponds to the Token URL text box on the Add Connection dialog box when the Type setting is Custom.
Possible values are URLs of the endpoints for requesting an access token.
Scopes
In the user interface, this property corresponds to the Scopes text box on the Add Connection dialog box. Scopes are optional. If the Type setting is Microsoft Entra ID and no scope is specified, the https://storage.azure.com/.default scope is added to user machines by default.
Possible values are strings that specify the scope of the access request.
<Scopes>
</Scopes>
