Color Management settings
System administrators can manage many ArcGIS Pro user application settings.
The settings described below should be added under the ColorManagement element in the Pro.settingsConfig file.
Learn more about color management options
WorkingColorSpaceForNewItems
In the user interface, on the Color Management tab on the Options dialog box, click Default color model for new items to access the corresponding setting.
Possible values are the following:
  • RGB (default)
  • CMYK
An example of this setting is shown below.
<WorkingColorSpaceForNewItems isLocked="true">CMYK</WorkingColorSpaceForNewItems>
EnableColorManagement
In the user interface, on the Color Management tab on the Options dialog box, click Enable color management to access the corresponding setting.
  • false (default)
  • true
<EnableColorManagement isLocked="true">true</EnableColorManagement>
RGBColorProfile
In the user interface, on the Color Management tab on the Options dialog box, click Color profiles > RGB to access the corresponding setting.
  • sRGB IEC61966-2.1 (default)
  • Any installed RGB color profiles
<RGBColorProfile isLocked="true">sRGB IEC61966-2.1</RGBColorProfile>
CMYKColorProfile
In the user interface, on the Color Management tab on the Options dialog box, click Color profiles > CMYK to access the corresponding setting.
  • U.S. Web Coated (SWOP) v2 (default)
  • Any installed CMYK color profiles
<CMYKColorProfile isLocked="true">U.S. Web Coated (SWOP) v2</CMYKColorProfile>
ColorConversionRule
In the user interface, on the Color Management tab on the Options dialog box, click Conversion rules > Color conversion rule to access the corresponding setting.
  • PreserveColorAppearance (default)
  • PreserveColorValues
<ColorConversionRule isLocked="true">PreserveColorValues</ColorConversionRule>
RenderingIntent
In the user interface, on the Color Management tab on the Options dialog box, click Conversion rules > Rendering intent to access the corresponding setting.
  • RelativeColorimetric (default)
  • Perceptual
  • Saturation
  • AbsoluteColorimetric
<RenderingIntent isLocked="true">Perceptual</RenderingIntent>
EnableDefaultBlackPointCompensation
In the user interface, on the Color Management tab on the Options dialog box, click Conversion rules > Use black point compensation to access the corresponding setting.
  • true (default)
  • false
<EnableDefaultBlackPointCompensation isLocked="true">false
</EnableDefaultBlackPointCompensation>
