Display settings
System administrators can manage many ArcGIS Pro user application settings.
The settings described below should be added under the Display element in the Pro.settingsConfig file.
Learn more about display options
AntialiasingMode
In the user interface, on the Display tab on the Options dialog box, click Set quality and performance options for drawing maps and scenes > Antialiasing mode to access the corresponding setting.
Possible values are the following:
NoneNormalFast(default)Best
An example of this setting is shown below.
<AntialiasingMode isLocked="true">Normal</AntialiasingMode>
TextAntialiasingMode
In the user interface, on the Display tab on the Options dialog box, click Set quality and performance options for drawing maps and scenes > Text antialiasing mode to access the corresponding setting.
NoneNormalForce(default)
<TextAntialiasingMode isLocked="true">Normal</TextAntialiasingMode>
StereoscopicMode
In the user interface, on the Display tab on the Options dialog box, click Stereoscopic mode to access the corresponding setting.
OFF(default)Native(3D shutter glasses)Anaglyph(3D cyan/red glasses)
<StereoscopicMode isLocked="true">Anaglyph</StereoscopicMode>
RenderingMode
In the user interface, on the Display tab on the Options dialog box, click Rendering engine to access the corresponding setting.
DirectX12(default)DirectX. This corresponds to DirectX 11 in the rendering engine display options.OpenGLVulkan
<RenderingMode isLocked="true">OpenGL</RenderingMode>
RenderingQuality
In the user interface, on the Display tab on the Options dialog box, click Set quality and performance options for drawing maps and scenes > Rendering quality to access the corresponding setting.
0(Low.)1(Middle.)2(High. This is the default.)
<RenderingQuality isLocked="true">1</RenderingQuality>
EnableVSync
In the user interface, on the Display tab on the Options dialog box, click Rendering engine > Enable vertical synchronization to access the corresponding setting.
true(default)false
<EnableVSync isLocked="true">false</EnableVSync>
EnableRenderingAntialiasing
In the user interface, on the Display tab on the Options dialog box, click Rendering engine > Enable hardware antialiasing to access the corresponding setting.
truefalse(default)
<EnableRenderingAntialiasing isLocked="true">true</EnableRenderingAntialiasing>
LocalCacheFolderPath
In the user interface, on the Display tab on the Options dialog box, click Local cache to access the corresponding setting.
Possible values are any valid local folder paths.
To specify an environment variable in the path, surround it with percent signs (%). For example, enter %USERNAME% to dynamically insert the username of the current user. In the Options dialog box, if the setting is unlocked, the variable is resolved once you enter the path. The full path is shown with the value of the variable expanded.
<LocalCacheFolderPath isLocked="true">C:\Users\%USERNAME%\AppData\Local\LocalCaches2</LocalCacheFolderPath>
ClearCacheWhenAppClosing
In the user interface, on the Display tab on the Options dialog box, click Local cache > Clear cache each time the application closes to access the corresponding setting.
truefalse(default)
<ClearCacheWhenAppClosing isLocked="true">true</ClearCacheWhenAppClosing>
UseSquarePrimitive
In the user interface, on the Display tab on the Options dialog box, click Set quality and performance options for drawing maps and scenes > Draw point clouds using squares to improve rendering performance to access the corresponding setting.
truefalse(default)
<UseSquarePrimitive isLocked="true">false</UseSquarePrimitive>
