ArcGIS Pro license levels
ArcGIS Pro is available at three license levels:
  • Basic—Included with the Creator user type
  • Standard—Included with the Professional user type
  • Advanced—Included with the Professional Plus user type
Learn more about user types
Core functionality is available with a Basic license. The Standard and Advanced licenses provide additional functionality in specialized areas.
The following tables describe functionality that requires a Standard or Advanced license. An Advanced license provides access to all the functionality available with a Standard license and more. A green check mark (Standard or Advanced license required) in a column means the indicated license is required to access the functionality.
The following tables are a general guide. A Standard or Advanced license may be required for some functionality not listed here. Help pages for specific operations and functions indicate when a Standard or Advanced license is required.
Data management, editing, and data validation
Functionality Requires Standard Requires Advanced Notes Examples
Create enterprise geodatabases and modify schema Standard or Advanced license required Create an enterprise geodatabase; create or delete feature classes, feature datasets, tables, or other items in an enterprise geodatabase
Create dimension feature classes Standard or Advanced license required
Edit dimension feature classes Standard or Advanced license required Also available with a Creator user type and Advanced Editing user type extension (AE UTE)
Create geodatabase topology Standard or Advanced license required
Edit features in a geodatabase topology Standard or Advanced license required Also available with Creator and AE UTE
Validate geodatabase topology Standard or Advanced license required Also available with Creator and AE UTE
Use Error Inspector to review topology errors Standard or Advanced license required Also available with Creator and AE UTE
Create attribute rules Standard or Advanced license required
Run batch calculate and validation rules Standard or Advanced license required Also available with Creator and AE UTE
Use Error Inspector to review attribute rule errors Standard or Advanced license required Also available with Creator and AE UTE
Reconcile, post, inspect conflicts, differences, and purge lock in a branch versioned geodatabase Standard or Advanced license required Also available with Creator and AE UTE
Create and manage geodatabase replicas Standard or Advanced license required
Generate licensed file geodatabases Standard or Advanced license required
Perform data validation checks Standard or Advanced license required Also available with a Creator user type and the ArcGIS Data Reviewer extension Attribute, event, feature integrity, polygon, polyline, spatial relationship, and z-value checks
Create and use file knowledge graphs Standard or Advanced license required
Networks and topological fabrics
This section includes utility networks, trace networks, and parcel fabrics.
Utility networks
Validate network Standard or Advanced license required Also available with Creator and AE UTE
Convert geometric networks from ArcGIS Desktop to trace networks Standard or Advanced license required Also available with Creator and AE UTE
Edit features and associations Standard or Advanced license required Also available with Creator and AE UTE
Modify terminal paths and connections Standard or Advanced license required Also available with Creator and AE UTE
Manage subnetwork controllers Standard or Advanced license required Also available with Creator and AE UTE
Edit, save, or generate network diagrams Standard or Advanced license required Also available with Creator and AE UTE
Use Error Inspector to review errors Standard or Advanced license required Also available with Creator and AE UTE
Create or modify network schema Standard or Advanced license required
Publish utility network Standard or Advanced license required
Trace networks
Edit features Standard or Advanced license required Also available with Creator and AE UTE
Publish trace network Standard or Advanced license required
Parcel fabrics
Edit parcels Standard or Advanced license required Also available with Creator and AE UTE
Record management and Active Record Standard or Advanced license required Also available with Creator and AE UTE
Take a parcel fabric offline Standard or Advanced license required Also available with Creator and AE UTE
Least squares adjustment Standard or Advanced license required Also available with Creator and AE UTE
Create or modify parcel fabric schema Standard or Advanced license required
Publish parcel fabric Standard or Advanced license required
Imagery and remote sensing
Create mosaic datasets Standard or Advanced license required
Migrate raster catalogs from ArcGIS Desktop to mosaic datasets Standard or Advanced license required
Create and manage ortho mapping workspaces Advanced license required
Generate elevation data and orthomosaics from image collections Advanced license required
Exploratory analysis
Interactive object detection Advanced license required
Graph analytics Advanced license required Works with file knowledge graphs Link charts, graph queries, centrality, Filtered Find Paths tool, and other graph analytic tools
Simulation
Flood simulation Advanced license required
LocateXT (Location extraction from text)
Search text or documents for spatial locations and generate point features representing those locations Standard or Advanced license required
Geoprocessing tools
See Geoprocessing licensing for license requirements by toolbox.
