ArcGIS Pro Performance Assessment Tool
The ArcGIS Pro Performance Assessment Tool (PAT) is a set of tests that assesses a computer's ability to run key ArcGIS Pro workflows. You can use it to investigate a perceived performance issue on its own or with the help of Esri Technical Support. You can use the PAT to do the following:
PAT tests various functionality at three test levels:
Level Description
1 A concise test of map rendering and geoprocessing analysis
2 A more in-depth test of 3D rendering, editing, projection, and geoprocessing tasks
3 A set of geoprocessing analysis and 3D visibility tests for more thoroughly exercising CPU/GPU including CUDA, where applicable
Learn more about what's included with the ArcGIS Pro PAT download
