Selection settings
System administrators can manage many ArcGIS Pro user application settings.
The settings described below should be added under the Selection element in the Pro.settingsConfig file.
Learn more about selection options
KeepInvisibleFeaturesSelected
In the user interface, on the Selection tab on the Options dialog box, click Keep invisible features selected with a new selection to access the corresponding setting.
Possible values are the following:
truefalse(default)
An example of this setting is shown below.
<KeepInvisibleFeaturesSelected isLocked="true">false</KeepInvisibleFeaturesSelected>
SaveWithCurrentSelection
In the user interface, on the Selection tab on the Options dialog box, click Save layers and tables with their current selection to access the corresponding setting.
true(default)false
<SaveWithCurrentSelection isLocked="true">false</SaveWithCurrentSelection>
UseSelectByGeometry
In the user interface, on the Selection tab on the Options dialog box, click Use database geometry (2D only) to access the corresponding setting.
truefalse(default)
<UseSelectByGeometry isLocked="true">false</UseSelectByGeometry>
