Table settings
System administrators can manage many ArcGIS Pro user application settings.
The settings described below should be added under the Table element in the Pro.settingsConfig file.
Learn more about table options
DisableAddRow
In the user interface, on the Table tab on the Options dialog box, click Set options for adding new rows > Hide the 'Click to add new row' option for feature class tables to access the corresponding setting.
Possible values are the following:
  • true
  • false (default)
An example of this setting is shown below.
<DisableAddRow isLocked="true">true</DisableAddRow>
DisableAutoRefresh
In the user interface, on the Table tab of the Options dialog box, click Refresh the table when changes are made to access the corresponding setting.
  • true (default)
  • false
<DisableAutoRefresh isLocked="true">true</DisableAutoRefresh>
AllowWebLinks
In the user interface, on the Security tab on the Options dialog box, click Allow web links to access the corresponding setting.
  • true (default)
  • false
<AllowWebLinks isLocked="true">false</AllowWebLinks>
SupportedURISchemeList
Use this setting if AllowWebLinks is set to true. In the user interface, on the Security tab on the Options dialog box, click Allow web links > Supported URI schemes to access the corresponding setting.
Many URI schemes are supported. Open the Security options and browse the list to see the available choices. Additional URI schemes can be added.
<SupportedUriSchemeList isLocked="true">ftp,ftps,http</SupportedUriSchemeList>
AllowFileLinks
In the user interface, on the Security tab on the Options dialog box, click Allow file links to access the corresponding setting.
  • true (default)
  • false
<AllowFileLinks isLocked="true">false</AllowFileLinks>
SupportedFileExtensionList
Use this setting if AllowFileLinks is set to true. In the user interface, on the Security tab on the Options dialog box, click Allow file links > Supported file extensions to access the corresponding setting.
Many file extensions are supported. Open the Security options and browse the list to see the available choices. Additional file extensions can be added.
<SupportedFileExtensionList isLocked="true">.7z,.csv</SupportedFileExtensionList>
FontName
In the user interface, on the Table tab on the Options dialog box, click Set options for table appearance > Table font to access the corresponding setting.
Possible values are those that appear in the Font drop-down list. Segoe UI is the default.
<FontName isLocked="true">Tahoma</FontName>
FontSize
Possible values are the following, which appear in the Size drop-down list:
  • 8
  • 9
  • 10
  • 11 (default)
  • 12
  • 14
  • 16
  • 18
  • 20
  • 22
  • 24
  • 26
  • 28
  • 36
  • 48
  • 72
<FontSize isLocked="true">11</FontSize>
FilterByTime
In the user interface, on the Table tab on the Options dialog box, click Set options for filtering tables > Time to access the corresponding issue
  • true (default)
  • false
An example of this setting is shown below:
<FilterByTime isLocked="true">true</FilterByTime>
FilterByExtent
In the user interface, on the Table tab on the Options dialog box, click Set options for filtering tables > Extent to access the corresponding issue
  • true
  • false (default)
<FilterByExtent isLocked="true">false</FilterByExtent>
FilterByRange
In the user interface, on the Table tab on the Options dialog box, click Set options for filtering tables > Range to access the corresponding issue
  • true (default)
  • false
<FilterByRange isLocked="true">true</FilterByRange>
