Virtual machine sizing and user profiles
When choosing the appropriate configuration size for ArcGIS Pro virtual machines (VMs), it's important to consider user needs and the virtual resources needed to accommodate them. To assist in this evaluation, the following user type categories are described:
  • Light user (viewing)—This user type works with a simple 2D map display, navigation, and querying. They combine and present data prepared by others.
  • Medium user (editing)—This user type works with 2D and 3D map display, navigation, querying, and editing, and uses geoprocessing tools. They compile and present data from multiple sources in a simple map layout.
  • Heavy user (visualizing)—This user type works with 2D and 3D map display, navigation, querying, and editing. They have advanced knowledge of symbology use, including transparency and dynamic labeling. This user does 2D and 3D analysis involving visibility and line of sight.
On-premises VM size recommendations
For organizations hosting ArcGIS Pro on-premises, the following are the recommended VM configurations for each user type:
User type
vCPU
Memory
vGPU profile
Light
Minimum 4 vCPU
Minimum 6 GB RAM
1Q–2Q
Medium
Minimum 8 vCPU
Minimum 8 GB RAM
2Q or greater
Heavy
Minimum 12 vCPU
Minimum 16 GB RAM
4Q or greater
Cloud VM size recommendations
There are several options for cloud VMs. The subsections below list the recommendations for Microsoft Azure and Amazon Web Services (AWS).
Azure single-session VM recommendations
In single-session scenarios, only one user is signed in to a session host virtual machine at a time. Using personal host pools in Azure Virtual Desktop is an example of a single-session scenario.
User type
Azure VM types
Light
NV4as_v4, NV8as_v4
Medium
NV16as_v4, NC4as_T4_v3, NV6ads_A10_v5
Heavy
NV18ads_A10_v5 or NC16as_T4_v3
Azure multisession VM recommendations
In multisession scenarios, multiple users are signed in to a session host simultaneously. Using pooled host pools in Azure Virtual Desktop with the Microsoft Windows 11 Enterprise multisession operating system (OS) is an example of a multisession deployment.
User type
Azure VM types
Maximum users per VM
Light
NV18ads_A10_v5, NC16as_T4_v3, NV32as_v4
6
Medium
Heavy
AWS EC2 instance type recommendations
The recommendations for AWS instance types are listed below.
User type
AWS EC2
Light
G4dn.xlarge
Medium
G4dn.4xlarge or G5.2xlarge
Heavy
G4dn.12xlarge or G5.4xlarge
