00082: Output parameter <value> in task <value> requires a result map service
The geoprocessing service you are creating uses an unsupported output data format. The result of the service can only be returned as an image by using a result map service.
Solution
You must return the result as a map image layer. Enable this from the Configuration page.
A result map service requires the output to be written to disk (not to the in_memory workspace) and the service to be set to asynchronous processing.
