00092: The <value> parameter is missing a description
The result you are attempting to publish is missing required item description information for one or more parameters. Parameter usage information is important to someone who is using your task, so they need to understand each parameter and its use.
Solution
For each parameter in your task, right-click the message and select Open sharing content pane to open the parameter pane and enter a useful parameter description.
Share as a web tool illustration.
More information
