00104: The <value> parameter is missing a syntax dialog explanation in the item description
The tool that created the result is missing the required dialog explanation for one or more parameters. Parameter explanations are important to users of the package, so they can understand each parameter and its use.
Solution
Using the Metadata editor, provide dialog reference descriptions for each parameter. The instructions in the Create a geoprocessing package topic explain how to document tool parameters.
