00178: Data: <value>; used by <value> cannot be copied to the server
The task you are attempting to publish as a geoprocessing service has data that cannot be copied to the GIS server, or the site has been purposefully configured by the site administrator so that data cannot be copied to the server. Data file types that cannot be copied, such as .exe, .bat, .dll, and so on, present a security risk.
Solution
The two possible solutions are as follows:
  • Remove the unsupported file. For example, if the script uses a folder and an unsupported file is contained in the folder, remove the unsupported file and continue publishing.
  • Set up a data store entry. Unsupported file types cannot be copied to the server, but you can reference the folder containing the file, ensuring that the server has access to the file and they are safe to use as a geoprocessing service. If your server administrator has disabled data copy during publishing, a data store entry will ensure that the server has access to the necessary data. Contact your server administrator for more information about setting up a data store or allowing data copy during publishing.
More information
Project data in a folder is copied when published to a server, unless the folder is registered with the server's data store.
