00412: At version <value> datasource <value> within Task <value> is not supported
This is an analyzer error message when publishing a web tool or geoprocessing service with a field data type that is not supported on ArcGIS Enterprise or ArcGIS Server. This is most commonly encountered with the following field types added to ArcGIS Pro 3.2 when publishing to ArcGIS Enterprise 11.1 or earlier:
Big integer
Date only
Time only
Timestamp offset
64-bit object IDs
Learn more about ArcGIS field data types
Solution
Upgrade ArcGIS Enterprise or ArcGIS Server to a version that supports the field data types.
If upgrading ArcGIS Enterprise or ArcGIS Server is not practical, modify the data so it does not include the new field data types.
