Understanding transformations and trends
Available with Geostatistical Analyst license.
Kriging as a predictor does not require that your data have a normal distribution. However, as you see in Understanding different kriging models, normality is necessary to obtain quantile and probability maps for ordinary, simple, and universal kriging. When considering only predictors that are formed from weighted averages, kriging is the best unbiased predictor whether or not your data is normally distributed. However, if the data is normally distributed, kriging is the best predictor among all unbiased predictors, not only those that are weighted averages.
Kriging also relies on the assumption that all the random errors are second-order stationarity, which is an assumption that the random errors have zero mean and the covariance between any two random errors depends only on the distance and direction that separates them, not their exact locations.
Transformations and trend removal can help justify assumptions of normality and stationarity. Prediction using ordinary, simple, and universal kriging for general Box-Cox, arcsine, and log transformations is called trans-Gaussian kriging. Log transformation is a special case of Box-Cox transformation, but it has special prediction properties and is known as lognormal kriging.
Transformations and trends for the primary variable
In the table below, the transformations and trend options available for each kriging method are shown for the primary variable. The table also shows whether transformation or trend removal is performed first when both are selected.
Kriging type
BAL
NST
Trend
Ordinary
Yes (1st if TR)
No
TR (2nd if BAL)
Simple
Yes
Yes
No
Universal
Yes (1st if T)
No
T (2nd if BAL)
Indicator
No
No
No
Probability*
No
No
No
Disjunctive
Yes (1st if TR)
Yes (2nd if TR)
TR (1st if NST, 2nd if BAL)
Empirical Bayesian
No
Yes
T (simultaneous with NST)
Empirical Bayesian 3D
No
Yes
T (simultaneous with NST), Z
EBK Regression Prediction
No
Yes
No
Primary variable transformations and trend options
*For probability kriging, the primary variable is composed of indicators of the original variable; the original variable is then considered a secondary variable for cokriging.
Transformations and trends for the secondary variable (cokriging)
In the table below, the transformation and trend options available for each kriging method are shown for the secondary variable. The table also shows whether transformation or trend removal is performed first when both are selected.
Kriging type
BAL
NST
Trend
Ordinary
Yes (1st if TR)
No
TR (2nd if BAL)
Simple
Yes
Yes
No
Universal
Yes (1st if T)
No
T (2nd if BAL)
Indicator
No
No
No
Probability
Yes (1st if TR)
Yes
TR (2nd if BAL)
Disjunctive
Yes (1st if TR)
Yes (2nd if TR)
Secondary variable transformations and trend options
Definitions and abbreviations
See the following for the meanings of the definitions and abbreviations used in the preceding tables.
Definitions
  • Primary variable—Variable to be predicted when using kriging or cokriging
  • Secondary variables—Covariables (not predicted) when using cokriging
  • Trend—Fixed effects composed of spatial coordinates used in a linear model
Abbreviations
  • BAL—Box-Cox, arcsine, and log transformations
  • NST—Normal score transformation
  • SV—Variable (covariables for cokriging)
  • T—(internal trend)
  • TR—Removal (external trend)
  • Z—Trend removal in vertical direction only
