Road Forks
Available with Network Analyst license.
The Road Forks table identifies pairs of edges (by EdgeFCID/FID/FrmPos/ToPos) where to explicitly place a driving directions instruction that the road forks.
The Road Forks table should reside in the same geodatabase workspace as the network dataset. The schema of the Road Forks table is as follows:
Field
Format
ObjectID
OID
ObjectID field
EdgeFCID
Long
The feature class ID of the line feature representing the starting edge
EdgeFID
Long
The feature ID of the line feature representing the starting edge
EdgeFrmPos
Double
The from position along the line feature representing the starting edge*
EdgeToPos
Double
The to position along the line feature representing the starting edge*
Branch0FCID
Long
The feature class ID of the line feature representing the first possible ending edge
Branch0FID
Long
The feature ID of the line feature representing the first possible ending edge
Branch0FrmPos
Double
The from position along the line feature representing the first possible ending edge*
Branch0ToPos
Double
The to position along the line feature representing the first possible ending edge*
Branch1FCID
Long
The feature class ID of the line feature representing the second possible ending edge
Branch1FID
Long
The feature ID of the line feature representing the second possible ending edge
Branch1FrmPos
Double
The from position along the line feature representing the second possible ending edge*
Branch1ToPos
Double
The to position along the line feature representing the second possible ending edge*
Branch2FCID
Long
The feature class ID of the line feature representing the third possible ending edge
Branch2FID
Long
The feature ID of the line feature representing the third possible ending edge
Branch2FrmPos
Double
The from position along the line feature representing the third possible ending edge*
Branch2ToPos
Double
The to position along the line feature representing the third possible ending edge*
*Notes regarding the from-position and to-position values:
  • For travel along the edge in the digitized direction of the line feature, the from-position value is less than the to-position value.
  • For travel opposite the digitized direction of the line feature, the from-position value is greater than the to-position value.
  • For line features not logically split midspan to create multiple edge elements, the from-position and to-position values are set to 0.0 and 1.0, respectively. Otherwise, these values are set to the fractional values where the logical splits occur for the edge element.
For best performance, it is strongly recommended that a separate attribute index is created for each of the following fields on the road forks table:
  • EdgeFCID
  • EdgeFID
Learn more about indexing an attribute
