Types of evaluators used by a network
Available with Network Analyst license.
Each attribute defined in the network must have values for each source participating in the network. An evaluator assigns values for the attribute of each source. The Field Script evaluator assigns an evaluator from a field of a network source to a combination of a network attribute, source, and direction. In addition, there are other types of evaluators that can be used, including Constant, Function, and Element Script evaluators.
The evaluators are described below.
Evaluator |
Description |
Field Script |
The most common way to assign values for a network attribute is to identify a single field that will be used to evaluate the network attribute when the network dataset is built. For example, a field evaluator can be used in cases in which the value describes a measurement, such as the length of each road segment in meters. Tip:For cost attributes with units of distance, use the Note that the The field evaluator can be modified to take a field expression as the value instead of a single field. For example, if the units of the network attribute are in meters but the units of source data are in feet, you can create an expression to convert the feet to meters when the network dataset is built. See examples for Field Script evaluator Legacy:In earlier versions of ArcGIS Pro, Field Script evaluators could be configured using VBScript. Although it is still possible to solve a network analysis using a VBScript-based Field Script evaluator, these evaluators must be updated to Python before the network can be edited. |
Constant |
Attributes can be assigned a constant value. The value can be numeric for cost, descriptor, and hierarchy attributes, or a Boolean data type of Use Restriction or Ignore Restriction for a restriction attribute. |
Function |
The Function evaluator calculates attribute values by performing a simple mathematical operation or logical comparison on another attribute value and a parameter value or constant. For numeric attribute types, the values can be derived by multiplying, dividing, adding, or subtracting another network attribute and a constant or parameter value. For Boolean attribute types, the values are derived from an expression that compares another attribute value to a parameter value or constant, for example, MaxHeight < VehicleHeight. Legacy:The addition ( The addition ( |
Turn Category |
The Turn Category evaluator assigns a default cost value for transitioning between two edge elements. The cost is based on the deflection angle between the two edges and the road class (primary, secondary, or local) of the edges that are traversed. It can also depend on the category of the crossroad being crossed by the turn movement. For example, you can use the Turn Category evaluator to make all left turns, which are determined by deflection angles, from local roads onto secondary roads take longer than left turns from local roads onto other local roads. You can also specify added costs for other transitions, such as adding a 10-second delay when continuing straight at an intersection of two secondary roads. |
Element Script |
Attributes can be assigned from the result of running a Python script. This provides a way to model complex attributes. Unlike other evaluators, the Element Script evaluator does not assign values when a network is built. Instead, it assigns values when a network analysis requires the use of that attribute, which can occur at solve time. If the values of an attribute change constantly, the use of the Element Script evaluator can ensure that attributes are updated for each network analysis. Tip:Because the Element Script evaluator calculates its values at the time of analysis, this evaluator tends to negatively affect analysis performance. Use another evaluator if possible. See examples for Element Script evaluator Legacy:In earlier versions of ArcGIS Pro, Element Script evaluators could be configured using VBScript. VBScript-based Element Script evaluators are no longer supported and must be updated to Python before the network can be used for analysis |
Traffic |
Traffic evaluators are designed for traffic data. They can provide travel times for a given time of day and day of the week using historical or live data. They include fallback cost attributes that provide weekday and weekend travel times when specific time-of-day travel times are not available. Traffic evaluators also have a time-independent cost attribute that Network Analyst references when sequencing stops in a route analysis or visits in a vehicle routing problem, and also when the analysis does not specify arrival or departure time. |
Public Transit |
The Public Transit evaluator calculates the travel time along a public transit line segment based on the scheduled public transit service. The travel time returned includes the wait time until the next scheduled transit trip begins plus the travel time along the transit line segment from one end to the other. Use this evaluator to model people traveling by public transit. It's not designed to model the travel time of buses driving along roads. The Public Transit evaluator is only available for time-based cost attributes on edge sources known as |
Same as Default |
There is a default evaluator type for each Source category. When a source evaluator type is set to Same as Default, it uses the evaluator that is set as the default. |
Same as Along |
When a source evaluator type in the Edges category is set to Same as Along, it uses the evaluator that is used by the source feature Street (Along). |
Unsupported |
The evaluator is not supported by the current version of ArcGIS Pro. |
You'll need to rebuild network datasets if the changes you make require the network dataset to access its source feature classes. For instance, creating a field evaluator that pulls time costs from a source feature class requires the network to be rebuilt. Changing the geometry of source features requires the network dataset to be rebuilt. However, the network doesn't need to be rebuilt with other types of evaluators, since these evaluators don't draw information directly from the source feature classes.
