Boolean Not function
Available with Image Analyst license.
Available with Spatial Analyst license.
Overview
Performs a Boolean Not (complement) operation on the pixel values of the input raster.
If the input values are true (nonzero), the output value is 0. If the input values are false (zero), the output value is 1.
Notes
The Boolean math tools interpret the inputs as Boolean values, where nonzero values are considered true, and zero is considered false.
Only a single input is necessary for this Boolean evaluation to take place.
If the input values are floating point, they are converted to integer values of either 0 or 1 before the operation is performed. If the input value is a floating point 0.0, it is converted to an integer 0. If the input is any value other than 0.0, it is converted to an integer 1. For example, input float values of 0.6, 32.22, and -4.2 will all be treated as being 1. The output values are always integer.
If the input is a multiband raster, the output will be a multiband raster. The function will perform the operation on each band in the input.
If the input is a multidimensional raster, all slices from all variables will be processed, and the output will be a multidimensional raster.
Parameters
Parameter name |
Description |
Raster |
The first input to use in this Boolean operation. |
Extent Type |
Choose which extent should be used in the output raster:
Cellsize Type |
Choose which cell size to use in the output raster. If all the input cell sizes are the same, all the options will yield the same results.
