Create radial lines of sight
Available with 3D Analyst license.
The Radial Line of Sight tool shows terrain visibility from a location using observer information. Using a surface and one or more observer locations, the tool shows areas that are visible to one or more observers or not visible to any.
To add radial line of sight analysis to models or scripts, you can use the Radial Line Of Sight geoprocessing tool in your workflow.
Open the Radial Line of Sight tool
To open the Radial Line of Sight tool, complete the following steps:
On the ribbon, click the Analysis tab.
In the Workflows group, click Visibility Analysis
.In the Visibility Analysis pane, click the Radial Line Of Sight tab
Add surface information
The Radial Line of Sight tool requires surface information to perform calculations.
To add surface information, complete the following steps:
Click the Input Surface drop-down list.
Select an elevation surface layer from the Contents pane.
The elevation surface layer must be in a projected coordinate system.
Caution:
The use of a global or large area extent image service results in excessive processing time. It is recommended that you use a local dataset or a small area extent image service.
Input observer points
You create radial lines of sight by specifying one or more observer locations.
Input points manually
To add observer locations manually by providing known coordinates or by selecting locations from the map, complete the following steps:
Click the Observer Points drop-down arrow, and click Enter Manually.
In the Observer Points text box, provide a coordinate and press Enter to add it to the list.
Alternatively, click Observer Map Point Tool
, and click the map.On the map, observer points are marked with blue circles.
Input points from a list
You can add observer locations by copying and pasting a list of coordinates or importing a .csv file.
Input points by copying and pasting
To use copy and paste functionality to add points to the Radial Line of Sight tool, complete the following steps:
Copy a list of observer point coordinates in which each coordinate pair is entered on a separate line.
Right-click in the Observer Points list box, and click Paste.
Input points from a .csv file
To import a .csv file to add points to the Radial Line of Sight tool, complete the following steps:
Right-click in the Observer Points list box, and click Import.
Browse to the
.csvfile where the observer points are stored, and click OK.On the Select Fields dialog box, specify which fields in the
.csvfile store the coordinates.Click OK.
Observer points are marked with blue circles.
Input points from a layer
To add observer locations by selecting a layer from the Contents pane of a map, complete the following steps:
Click the Observer Points drop-down arrow.
Choose an available layer.
Change symbology
To change the way the Radial Line of Sight tool outputs are symbolized, complete the following steps:
Optionally, check the Symbolize non-visible data in output check box.
If the box is unchecked (the default), nonvisible areas are symbolized with no color. If the box is checked, nonvisible areas are symbolized in red.
Optionally, uncheck the Symbolize multiple observers check box.
If the box is checked (the default), visible areas are symbolized differently according to the number of observers who can see them. If the box is unchecked, all visible areas have the same symbol regardless of how many observers can see them.
Name the output
To name the radial line of sight output, provide a name in the Output Radial Line of Sight text box.
The Radial Line of Sight tool produces a feature dataset in the default geodatabase with two feature classes. The name provided in the Output Radial Line of Sight text box is used to name the feature dataset and is prepended to the feature classes in the feature dataset. If a feature dataset with this name already exists, the tool automatically appends a number to the name in the Output Radial Line of Sight text box and uses that name.
The Radial Line of Sight tool output is added to the Contents pane in a group layer. The name used for the feature dataset is also used for the group layer.
Specify observer information
To specify the observer information, complete the following steps:
Expand Observer Options.
Change the observer information by doing the following, or accept the defaults:
Under Height Above Surface, provide values in the Observer and Surface text boxes.
Click the drop-down arrow to select the unit of measure for observer and surface height.
Under Distance, provide values in the text boxes for the minimum (nearest) and maximum (farthest) linear distances to be analyzed for visibility.
Click the drop-down arrow to select the unit of measure for distance.
Under Field of View, provide values in the Horizontal and Vertical text boxes to constrain the field of view of the observer.
Click the drop-down arrow to select the angular units for field of view.
Click OK to calculate visible areas.
Areas visible to an observer are shown in green. By default, if an area is visible to more than one observer, it is shown with a unique color indicating the number of observers that can see it.
Tip:
You can refine the analysis by changing the height, distance, or field of view settings.
Click Cancel to remove the observer coordinates from the tool.
When using the Radial Line of Sight tool in a global or local scene, you must add a local elevation surface. The default World Elevation 3D/Terrain 3D surface in a scene cannot be used by the tool.
