Multifile feature connection file properties
Multifile feature connection datasets have a file property that defines the dataset type and its format.
The following are some examples of when you should update your field information:
To verify the correct file type was selected (delimited, shapefile, ORC, parquet)
To modify the quote character
To modify the encoding
Field properties details
Every data type includes a file format type: delimited, shapefile, ORC, or parquet.
Delimited files have additional properties that are not supported for shapefile, ORC, and parquet. The additional properties include the following:
File extension—The extensions of the delimited file, for example,
.csv. This property is not editable.Field delimiter—The delimiter used to split fields. This property is editable.
Record terminator—The character used to split lines. This property is editable.
Quote character—The character used for quotes within a string. This property is editable.
Escape character—The character used to escape quotes. This property is editable.
Has header row—If the delimited file has a header row. This property is editable.
Encoding—The type of encoding. The default is UTF-8. This property is editable.
Changing the file properties for the multifile feature connection dataset does not modify your source datasets.
