Reserved CAD fields for MicroStation V8 DGN formats
The following table lists the field names that are reserved for reading and writing V8 DGN CAD data in ArcGIS Pro. You can use them to override the default output of the Export To CAD tool by adding them to the input feature class table. Fields marked as read-only are exclusive to direct-read CAD (virtual) attribute tables and cannot be used.
Category |
Field name |
Data type |
Length |
Description |
Element properties |
OID |
ObjectID |
4 |
A unique feature identifier
Shape |
Geometry |
The ArcGIS area shape representing the spatial extent of the CAD file
Entity |
String |
16 |
The CAD entity
Handle |
String |
16 |
A unique CAD entity identifier
Angle |
Double |
8 |
Rotation angle in degrees
<attribute name> |
Text, Long, or Double |
8 |
A named user-defined textual entity used for storing data |
CadModel |
String |
255 |
A DGN file component that contains elements |
CADModelID |
String |
255 |
String representing the index number of the CAD model |
Class |
String |
255 |
The entity class designation |
Color |
Short |
2 |
The display color of the entity expressed as an integer |
Elevation |
Double |
8 |
The z-coordinate value of an entity.
EntColor |
Short |
2 |
The assigned color of the entity expressed as an integer |
EntLinetype |
String |
255 |
The assigned line type of the entity |
EntLineWt |
Short |
2 |
The assigned line weight of an entity |
Fill |
Short |
2 |
Fill pattern name |
GGroup |
Short |
2 |
The graphic group to which an entity belongs |
LineWt |
Short |
2 |
The display line weight of an entity |
Linetype |
String |
255 |
The display line type of the entity |
LTScale |
Double |
8 |
The scale of the entity's line type |
ObjectHandle |
String |
255 |
Hexadecimal identifier of associated tag elements for TextPoint or Annotation feature classes |
MsLink_Oracle |
Long |
4 |
A unique identifier used as a primary key for linking a graphic element to a record in an external database table |
MsCtlg_Oracle |
Long |
4 |
An identifier in the MSCatalog relation table that uniquely identifies the table containing the MSLink. The MSCatalog table is used by the MicroStation database server and stored in the target database |
QrotW |
Double |
8 |
The w-coordinate quaternion (3D) rotation value |
QrotX |
Double |
8 |
The x-coordinate quaternion (3D) rotation value |
QrotY |
Double |
8 |
The y-coordinate quaternion (3D) rotation value |
QrotZ |
Double |
8 |
The z-coordinate quaternion (3D) rotation value |
RefName |
String |
255 |
The name of the parent object in which the entity resides |
Layer properties |
Layer |
String |
255 |
The CAD drawing layer name |
Level |
Long |
4 |
The CAD drawing layer number identifier |
LvlDesc |
String |
255 |
The description of the CAD level
LvlPlot |
Short |
2 |
The CAD plot order of the drawing levels |
LyrColor |
Short |
2 |
The CAD drawing layer color expressed as an integer |
LyrFrzn |
Short |
2 |
The freeze/thaw state of the CAD drawing layer.
LyrLntype |
String |
255 |
The line type of the CAD drawing layer in which the entity resides |
LyrLineWt |
Short |
2 |
The line weight of the CAD drawing layer in which the entity resides |
LyrLock |
Short |
2 |
The lock/unlock state of the CAD drawing layer.
LyrOn |
Short |
2 |
The on/off state of the CAD drawing layer.
Text properties |
FontId |
Short |
2 |
The ArcGIS text symbol ID
Height |
Double |
8 |
The text height in CAD units |
LnSpace |
Short |
2 |
The multiline text spacing type
SpaceFact |
Double |
8 |
The multiline text spacing factor
TextString |
String |
2048 |
The text string with ArcGIS Pro formatting codes |
TxtAttach |
Short |
2 |
The multiline text attachment parameter |
TxtBoxHt |
Double |
8 |
The text entity bounding box height |
TxtBoxWd |
Double |
8 |
The text entity bounding box width |
FontName |
String |
255 |
Text entity CAD font name |
TxtDir |
Short |
2 |
The multiline text direction parameter |
TxtMemo |
String |
2048 |
The entire text string, not truncated. However, this field has a limit of 4,000 characters.. |
TxtOblique |
Double |
8 |
The text entity oblique angle |
TxtRefWd |
Double |
8 |
The multiline text width factor.
TxtWidth |
Double |
8 |
The text entity width factor
HorizontalAlignment |
Integer |
4 |
The text entity horizontal alignment parameter |
VerticalAlignment |
Integer |
4 |
The text entity vertical alignment parameter |
Document properties |
DocName |
String |
255 |
The file name of the CAD file including the extension |
DocPath |
String |
4096 |
The full path of the CAD file including the file name.
DocType |
String |
32 |
The file extension associated with the CAD format |
DocUpdate |
Date |
255 |
The time stamp of the last update to that entity in CAD |
DocVer |
String |
16 |
The CAD format version |
DocId |
Double |
8 |
CAD document identification number |
