Reserved CAD fields for AutoCAD DWG/DXF formats
The following table lists the field names that are reserved for reading and writing DWG/DXF CAD data in ArcGIS Pro. You can use them to override the default output of the Export To CAD tool by adding them to the input feature class table. Fields marked as read-only are exclusive to direct-read CAD (virtual) attribute tables and cannot be used.
Category |
Field name |
Data type |
Length |
Description |
Entity properties |
FID |
ObjectID |
4 |
A unique feature identifier
Shape |
Geometry |
The ArcGIS area shape representing the spatial extent of the CAD file
Entity |
String |
16 |
The CAD entity |
Handle |
String |
16 |
A unique CAD entity identifier
Angle |
Double |
8 |
Rotation angle in degrees
<attribute name> |
Text, Long, or Double |
8 |
A named user-defined textual entity used for storing data in a block insert |
BlkColor |
Short |
2 |
The color assigned to the block expressed as an integer |
BlkLinetype |
String |
255 |
The line type of the block with which the entity is associated |
BlkLineWt |
Short |
2 |
The line weight of the block with which the entity is associated |
CadType |
String |
255 |
A valid value overrides the default output entity type, for example:
Other entity types require companion fields that specify parameters, for example:
Color |
Short |
2 |
The display color of the entity expressed as an integer
DocUpdate |
Date |
N/A |
Timestamp of last update to that Entity in CAD |
Elevation |
Double |
8 |
The z-coordinate value of an entity
EntColor |
Short |
2 |
The assigned color of the entity expressed as an integer |
EntLinetype |
String |
255 |
The assigned line type of the entity |
EntLineWt |
Short |
2 |
The assigned line weight of an entity |
ExtX |
Double |
8 |
The x-coordinate extrusion value
ExtY |
Double |
8 |
The y-coordinate extrusion value
ExtZ |
Double |
8 |
The z-coordinate extrusion value
LineWt |
Short |
2 |
The display line weight of an entity |
Linetype |
String |
255 |
The display line type of the entity |
LTScale |
Double |
8 |
The scale of the entity's line type |
RefName |
String |
255 |
The name of the parent object in which the entity resides |
ScaleX |
Double |
8 |
The x-coordinate scale value
ScaleY |
Double |
8 |
The y-coordinate scale value
ScaleZ |
Double |
8 |
The z-coordinate scale value
Thickness |
Double |
8 |
The extrusion distance of an entity |
Layer properties |
Layer |
String |
255 |
The CAD drawing layer name |
LyrColor |
Short |
2 |
The CAD drawing layer color expressed as an integer |
LyrFrzn |
Short |
2 |
The freeze/thaw state of the CAD drawing layer
LyrHandle |
String |
16 |
A unique CAD drawing layer identifier
LyrLnType |
String |
255 |
The line type of the CAD drawing layer in which the entity resides |
LyrLineWt |
Short |
2 |
The line weight of the CAD drawing layer in which the entity resides |
LyrLock |
Short |
2 |
The lock/unlock state of the CAD drawing layer
LyrOn |
Short |
2 |
The on/off state of the CAD drawing layer.
LyrVPFrzn |
Short |
2 |
The freeze/thaw state of the CAD view port |
Text properties |
FontId |
Short |
2 |
The ArcGIS text symbol ID
Height |
Double |
8 |
The text height in CAD units |
LnSpace |
Short |
2 |
The multiline text spacing type
SpaceFact |
Double |
8 |
The multiline text spacing factor
TxtStyle |
String |
255 |
The text style |
Text |
String |
255 |
The text string without formatting codes |
TextString |
String |
2048 |
The text string with ArcGIS Pro formatting codes |
TxtAttach |
Short |
2 |
The multiline text attachment parameter |
TxtBoxHt |
Double |
8 |
The text entity bounding box height |
TxtBoxWd |
Double |
8 |
The text entity bounding box width |
TxtDir |
Short |
2 |
The multiline text direction parameter |
TxtFont |
String |
255 |
The text entity CAD font |
TxtGenType |
String |
32 |
The text generation type
TxtHt |
Double |
8 |
The text entity height |
TxtJust |
String |
32 |
The text entity justification parameter |
TxtMemo |
String |
2048 |
The entire text string with CAD formatting codes, not truncated. If the field exceeds 4,000 characters, it will allow this to be converted and needs to be shortened. |
TxtOblique |
Double |
8 |
The text entity oblique angle |
TxtRefWd |
Double |
8 |
The multiline text width factor
Angle |
Double |
8 |
The text entity rotation angle |
TxtValue |
String |
255 |
The text string for new text created from point features when the field CADType contains the keyword TEXT |
TxtWidth |
Double |
8 |
The text entity width factor
VertAlign |
String |
32 |
The text entity vertical alignment parameter |
Document properties |
DocName |
String |
255 |
The file name of the CAD file including the extension |
DocPath |
String |
4096 |
The full path of the CAD file including the file name DocPath can be used to export a single feature class to multiple CAD drawings when Ignore Paths is unchecked on the Export To CAD tool dialog box. |
DocType |
String |
255 |
The file extension associated with the CAD format |
DocVer |
String |
16 |
The CAD format version |
