Supported Autodesk Civil 3D data
Direct-read support of AutoCAD Civil 3D objects extends the support of standard AutoCAD DWG files. Additional CAD feature classes are generated from AutoCAD Civil 3D objects included in the drawing file. Many of these feature classes, when added to a map or scene, are rendered with enhanced symbology to mimic their symbology in AutoCAD Civil 3D. Each resulting feature from these AutoCAD Civil 3D objects includes design data properties that are included as feature attributes. These feature attributes include AutoCAD graphic properties, various AEC entity properties, and user-defined property sets.
AutoCAD Civil 3D objects |
Esri geometry type |
Alignment |
Polyline |
Alignment Profile |
Polyline |
Appurtenance |
Point |
Breakline |
Polyline |
Catchment |
Polygon |
COGO Point |
Point, Multipoint (if grouped) |
Corridor Assembly |
Multipatch |
Feature Line |
Polyline |
Fitting |
Point |
Grading |
Polyline |
Gravity Network |
Multipatch |
Parcel |
Polygon, Polyline |
Parcel Segment |
Polyline |
Pipe |
Polyline |
Pressure Network |
Multipatch |
Pressure Pipe |
Polyline |
Profile Vertical Intersect |
Point |
Site |
Polygon |
Station Equation |
Point |
Structure |
Point |
Surface Point |
Multipoint |
Surface Border |
Polygon |
Surface Boundary |
Polyline |
Surface Contour |
Polyline |
Topography ( |
Multipatch |
Surface points are not automatically loaded when the entire drawing is added to a map. To add the surface points to a map or scene, you can select and add it as an individual feature class from the CAD dataset.
See also
Supported AutoCAD and MicroStation geometry
