Get started with Coordinate Conversion
It is common for users to work across various systems that use different coordinate systems to identify locations on the earth. For example, your coordinates may be in one coordinate system and another application may require the same location using a different coordinate system. Using Coordinate Conversion, you can input coordinates using one coordinate system and output them to different coordinate systems in multiple notation formats.
Caution:
Coordinate Conversion requires inputs to be in the WGS84 geographic coordinate system .
Coordinate Conversion tools
To open the Coordinate Conversion tools, complete the following steps:
On the ribbon, click the Map tab.
In the Inquiry group, click Coordinate Conversion
