Supported formats with the Data Interoperability extension
Available with Data Interoperability license.
All formats supported by the Data Interoperability extension are uniquely identified by an uppercase alphanumeric string. Some formats support reading and writing, and others support only reading or writing exclusively. Some formats are only available for download on the FME HUB.
For more detailed information about these specific FME Reader and Writer formats, you can access the documentation through the Data Interoperability Workbench application dialog boxes using the help button.
Supported formats
Short Name Description Reader/Writer Available on FME Hub
12DXML 12d Model Reader/Writer
3DS Autodesk 3ds Reader/Writer
ACAD Autodesk AutoCAD DWG/DXF Reader/Writer
ADAC Australian Asset Design and As Constructed (ADAC) Reader/Writer
ADRG ADRG (ARC Digitized Raster Graphics) Reader
AIS NMEA Automatic Identification System (AIS) Reader
AIXM Aeronautical Information Exchange Model XML version 4.5 (AIXM 4.5) Reader/Writer
AIXM5 Aeronautical Information Exchange Model GML version 5.1 (AIXM 5.1) Reader/Writer
AIXM5X Aeronautical Information Exchange Model GML version 5.x (AIXM 5.x) Reader
AMAZON_MYSQL Amazon Aurora (MySQL-Compatible) Reader/Writer
AML S-57 Additional Military Layers (AML) Reader
APACHE_HIVE Apache Hive (Hadoop) Reader
ARCGEN Esri ArcInfo Generate Reader/Writer
ARCGISFEATURES Esri ArcGIS Server Feature Service Reader/Writer
ARCGISMAP Esri ArcGIS Map Document Reader
ARCGISONLINEFEATURES Esri ArcGIS Online (AGOL) Feature Services Reader/Writer
ARCGISPORTALFEATURES Esri ArcGIS Portal Feature Services Reader/Writer
ARCGIS_LAYER Esri ArcGIS Layer Reader
ARCINFO Esri ArcInfo Coverage Reader/Writer
ARCVIEWGRID Esri ArcGIS Binary Grid (AIG) Reader
ASRP ARC Standard Raster Product (ASRP) Reader
AUTOMATIONS FME Server Automations Writer
AZURE_TABLE Microsoft Windows Azure Table Reader/Writer
BAG Bathymetric Attributed Grid Reader/Writer
BASISU Basic Universal Reader/Writer
BCF BIM Collaboration Format (BCF) Reader/Writer
BMP Microsoft Bitmap (BMP) Reader/Writer
BSB Maptech BSB Nautical Chart Reader
CADRG CADRG (Compressed ARC Digitized Raster Graphics) Reader/Writer
CALS Continuous Acquisition and Life-cycle Support (CALS) Reader/Writer
CARTO CARTO Reader/Writer
CAT Column Aligned Text (CAT) Reader
CDED Canadian Digital Elevation Data (CDED) Reader/Writer
CESIUM3DPC Cesium 3D Point Cloud Reader/Writer
CESIUM3DTILES Cesium 3D Tiles Writer
CGDEF ComGraphix Data Exchange Format (CGDEF) Reader/Writer
CH.EHI.FME.MAIN Swiss INTERLIS (ili2fme) Reader/Writer
CIB CIB (Controlled Image Base) Reader/Writer
CITYGML OGC CityGML Reader/Writer
CITYGML3 OGC CityGML 3 (Tech Preview) Reader
CITYJSON CityJSON Reader/Writer
CIVIL3D Autodesk AutoCAD Civil 3D Reader
COG CoG (Cloud-Optimized GeoTIFF) Reader/Writer
COLLADA COLLADA (Collaborative Design Activity) Reader/Writer
COPC COPC (Cloud Optimized Point Cloud) Reader/Writer
CSV2 Comma-Separated Value (CSV) Reader/Writer
CUZK_GML CUZK GML (Czech Republic) Reader
DATABRICKS_JDBC Databricks (JDBC) Reader
DATAFILE Data File Reader/Writer
DB2 IBM Db2 Nonspatial Reader/Writer
DB2SPATIAL IBM Db2 Spatial Reader/Writer
DB2SPATIAL_DASHDB IBM Db2 Warehouse on Cloud Spatial Reader/Writer
DB2_DASHDB IBM Db2 Warehouse on Cloud Non-Spatial Reader/Writer
DB2_JDBC IBM Db2 (JDBC) Reader/Writer
DB2_JDBC_NONSPATIAL IBM Db2 Non-Spatial (JDBC) Reader/Writer
DBASE dBASE (DBF) Reader/Writer
DDS Microsoft DirectDraw Surface (DDS) Reader/Writer
DELORME_GPL DeLorme GPS Track Logs (GPL) Reader Reader
DELTALAKE Delta Lake Reader
DENODO Denodo Reader
DGNV8 Bentley MicroStation Design (V8) Reader/Writer
DICOM FILE Digital Imaging and Communications in Medicine Reader/Writer
DICOM_DIR Digital Imaging and Communications in Medicine Reader
DIRECTX Microsoft DirectX Reader/Writer
DLG Digital Line Graph (DLG) Reader
DMDF Digital Map Data Format (DMDF) Reader
DNF UK OS MasterMap Topography Layer (Non-XSD Driven, GML v2.1.2 Only) Reader
DOCUMENTDB Microsoft Azure Cosmos DB Reader/Writer
DSFL Danish DSFL Reader
DSFLW2 Danish DSFL Writer V.2 Writer
DTED DTED (Digital Terrain Elevation Data) Reader/Writer
DUCKDB DuckDB Reader
DWF Autodesk AutoCAD DWF Reader/Writer
DWML Digital Weather Markup Language Reader
DYNAMODB Amazon DynamoDB Reader/Writer
E00 Esri ArcInfo Export (E00) Reader/Writer
E57 ASTM E57 Reader/Writer
ELASTICSEARCH Elastic Elasticsearch v6.8 and earlier (deprecated) Reader/Writer
ELASTICSEARCH_CLUSTER Elastic Elasticsearch Reader/Writer
ENVIHDR ITT ENVI .HDR RAW Raster Reader/Writer
EPA_GDXML U.S. Environmental Protection Agency (EPA) Geospatial Data Reader
EPS Encapsulated PostScript (EPS) Writer
EPT Entwine Point Tile (EPT) Reader
ERDAS ERDAS IMAGINE Reader/Writer
ERDASRAW ERDAS RAW Reader/Writer
ERS ER Mapper ERS Reader/Writer
ESF BC MoF Electronic Submission Framework (ESF) Reader/Writer
ESF_XSD BC MoF Electronic Submission Framework (XSD- Driven) Reader/Writer
ESRIASCIIGRID Esri ASCII Grid Reader/Writer
ESRIHDR Esri.HDR RAW Raster Reader/Writer
ESRIJSON Esri_JSON (Esri JavaScript Object Notation) Reader/Writer
ESRIMSD Esri Mapping Specification for CAD (MSC) Reader/Writer
ESRI_KNOWLEDGE_GRAPH Esri Knowledge Reader/Writer
ESRI_MOBILE_GEODATABASE Esri Mobile Geodatabase Reader/Writer
FABRIC_WAREHOUSE_JDBC Microsoft Fabric (Data Warehouse) Reader/Writer
FACET Facet XDR Reader/Writer
FBX Autodesk FBX Reader/Writer
FFS FME Feature Store (FFS) Reader/Writer
FILECOPY File Copy Writer
FILEGDB Esri Geodatabase (File Geodatabase API) Reader/Writer
FITS FITS (Flexible Image Transport System) Reader/Writer
FLATGEOBUF FlatGeobuf Reader/Writer
FM0 Intergraph GeoMedia Access Warehouse Reader
FM0_SQL Intergraph GeoMedia SQL Server Warehouse Reader/Writer
FME_AR FME Augmented Reality (FME AR) Writer
FMW FME Workspace (FMW) Reader
GARMIN_GDB Garmin GDB Reader/Writer
GARMIN_GPI Garmin GPI Reader/Writer
GARMIN_POI Garmin POI Reader/Writer
GDAL_ACE2 ACE2 (from GDAL Format) Reader
GDAL_AIRSAR NASA JPL Airborne Synthetic Aperture Radar (AIRSAR) Polarimetric (from GDAL Format) Reader
GDAL_BLX Magellan BLX Topographical (from GDAL Format) Reader
GDAL_BT Virtual Terrain Project Binary Terrain Format (from GDAL Format) Reader
GDAL_COASP CEOS (Spot for instance) (from GDAL Format) Reader
GDAL_COSAR TerraSAR-X Complex SAR (Synthetic Aperture Radar) (from GDAL Format) Reader
GDAL_CPG Convair PolGASP (from GDAL Format) Reader
GDAL_CTG USGS Land Use and Land Cover (LULC) Composite Theme Grid (from GDAL Format) Reader
GDAL_DOQ1 First Generation USGS Digital Ortho Quad (DOQ) (from GDAL Format) Reader
GDAL_DOQ2 New Labelled USGS Digital Ortho Quad (DOQ) (from GDAL Format) Reader
GDAL_ECRGTOC Enhanced Compressed Raster Graphic (ECRG) Table Of Contents (from GDAL Format) Reader
GDAL_ELAS NASA Earth Resources Laboratory Applications Software (ELAS) (from GDAL Format) Reader
GDAL_FAST Earth Observation Satellite (EOSAT) Company FAST (from GDAL Format) Reader
GDAL_GENBIN Generic Binary (.hdr Labelled) (from GDAL Format) Reader
GDAL_GENERIC_RASTER GDAL Generic Raster Reader
GDAL_GFF Sandia National Laboratories GSat (from GDAL Format) Reader
GDAL_GSAG Golden Software ASCII Grid (from GDAL Format) Reader
GDAL_GXF Grid eXchange File (GXF) (from GDAL Format) Reader
GDAL_IRIS Interactive Radar Information System (IRIS) (from GDAL Format) Reader
GDAL_ISIS2 USGS Astrogeology International Satellites for Ionospheric Studies (ISIS) cube (Version 2) (from GDAL Format) Reader
GDAL_ISIS3 USGS Astrogeology International Satellites for Ionospheric Studies (ISIS) cube (Version 3) (from GDAL Format) Reader
GDAL_JAXAPALSAR Japanese Aerospace eXploration Agency (JAXA) Phased Array Type L-band Synthetic Aperture Radar (PALSAR) Product Reader (Level 1.1/1.5) (from GDAL Format) Reader
GDAL_JDEM Japanese Digital Elevation Model (DEM) (from GDAL Format) Reader
GDAL_KRO KRO (from GDAL Format) Reader
GDAL_L1B NOAA (National Oceanic and Atmospheric Administration) Polar Orbiter Level 1b Data Set - Advanced Very High Resolution Radiometer (AVHRR) (from GDAL Format) Reader
GDAL_LAN Erdas 7.x .LAN and .GIS (from GDAL Format) Reader
GDAL_LCP FARSITE v.4 Landscape (from GDAL Format) Reader
GDAL_LEVELLER Daylon Leveller Heightfield (from GDAL Format) Reader
GDAL_LOSLAS North America Datum Conversion Utility (NADCON) .los/.las Datum Grid Shift (from GDAL Format) Reader
GDAL_MAP OziExplorer .MAP (from GDAL Format) Reader
GDAL_MFF Vexcel Multi-File Format (MFF) (from GDAL Format) Reader
GDAL_MFF2 Vexcel Multi-File Format (MFF) 2 - Hierarchical Key Value (HKV) (from GDAL Format) Reader
GDAL_NDF National Land Archive Production System (NLAPS) (from GDAL Format) Reader
GDAL_NGSGEOID NOAA (National Oceanic and Atmospheric Administration) National Geodetic Survey (NGS) Geoid Height Grids (from GDAL Format) Reader
GDAL_OZI OziExplorer OZI OZF2/OZFX3 (from GDAL Format) Reader
GDAL_PAUX PCI .aux Labelled (from GDAL Format) Reader
GDAL_PCRASTER PCRaster (from GDAL Format) Reader
GDAL_PDS NASA Planetary Data System (from GDAL Format) Reader
GDAL_PNM Netpbm (from GDAL Format) Reader
GDAL_RMF Raster Matrix Format (from GDAL Format) Reader
GDAL_ROI_PAC NASA JPL (Jet Propulsion Laboratory) Repeat Orbit Interferometry Package (ROI PAC) Raster (from GDAL Format) Reader
GDAL_RS2 RadarSat2 XML (from GDAL Format) Reader
GDAL_SAGA System for Automated Geoscientific Analysis (SAGA GIS) Binary (from GDAL Format) Reader
GDAL_SAR_CEOS Synthetic Aperture Radar (SAR) CEOS (from GDAL Format) Reader
GDAL_SNODAS Snow Data Assimilation System (from GDAL Format) Reader
GDAL_TERRAGEN Terragen Heightfield (from GDAL Format) Reader
GDAL_TIL EarthWatch/DigitalGlobe (from GDAL Format) Reader
GDAL_TSX TerraSAR-X (from GDAL Format) Reader
GDAL_VICAR Video Image Communication And Retrieval (from GDAL Format) Reader
GDMS Geographic Data Management System (GDMS) Reader
GENAMAP Genasys GenaMap Reader
GENERIC Generic (Any Format) Reader/Writer
GEODATABASE_FILE Esri Geodatabase (File Geodatabase ArcObjects) Reader/Writer
GEODATABASE_FILE_MOSAIC_DATASET Esri Geodatabase (File Geodatabase Mosaic Dataset) Writer
GEODATABASE_FILE_RASTER_CATALOG Esri Geodatabase (File Geodatabase Raster Catalog) Reader
GEODATABASE_FILE_RASTER_DATASET Esri Geodatabase (File Geodatabase Raster Dataset) Reader/Writer
GEODATABASE_SDE Esri Geodatabase (ArcSDE Geodatabase) Reader/Writer
GEODATABASE_SDE_MOSAIC_DATASET Esri Geodatabase (ArcSDE Geodatabase Mosaic Dataset) Writer
GEODATABASE_SDE_RASTER_CATALOG Esri Geodatabase (ArcSDE Geodatabase Raster Catalog) Reader
GEODATABASE_SDE_RASTER_DATASET Esri Geodatabase (ArcSDE Geodatabase Raster Dataset) Reader/Writer
GEODATABASE_XML Esri Geodatabase (XML Workspace Document) Reader
GEOHASH Geohash Reader
GEOJSON Geographic JavaScript Object Notation (GeoJSON) Reader/Writer
GEONET NGA GEOnet Names Server Reader
GEOPACKAGE_RASTER OGC GeoPackage Tiles Reader/Writer
GEOPARQUET Apache GeoParquet Reader/Writer
GEORSS GeoRSS/RSS Feed Reader/Writer
GEOTIFF Georeferenced Tagged Image File Format (GeoTIFF) Reader/Writer
GG Bentley MicroStation GeoGraphics Reader/Writer
GIF GIF Rasterizer Writer
GIFRASTER GIF (Graphic Interchange Format) Reader/Writer
GLTF glTF (GL Transmission Format) Writer
GML GML (Geography Markup Language) Reader/Writer
GML2 GML v2.1.2 Writer
GML212 GML v2.1.2 Reader
GMLSF GML SF-0 (Geography Markup Language Simple Features Level SF-0 Profile) Reader/Writer
GOOGLE_MYSQL Google Cloud SQL (MySQL-Compatible) Reader/Writer
GPXX GPS eXchange Format (GPX) Reader/Writer
GRD PenMetrics GRD Reader/Writer
GRIB World Meteorological Organization GRIB (GRIdded Binary) Reader
GTFS General Transit Feed Specification (GTFS) Reader/Writer
GUESS_FROM_EXTENSION Guess format name from extension Reader
HDF4_ASTER Hierarchical Data Format 4 (HDF4) ASTER Reader
HDF4_HYPERION Hierarchical Data Format 4 (HDF4) Hyperion Reader
HEIF HEIF (High Efficiency Image File Format) Reader
HERE_VENUE_MAP HERE Venue Map (GML) Reader/Writer
HTML HTML Writer
HTMLTABLE HTML Table Reader
HXL_CSV HXL (Humanitarian Exchange Language) for CSV Reader
HYD93 NGDC Hydrographic Surveys Data Exchange (HYD93) Reader/Writer
HYPACKBRD Hypack Border Reader/Writer
I2KGML Swedish I2K/G2K (Interface 2000 GML) Reader/Writer
I3S Esri Indexed 3D Scene Layer Writer
IDRISI IDRISI Vector Format Reader/Writer
IDRISI_RASTER IDRISI Raster Format Reader/Writer
IEPS Adobe Illustrator EPS Writer
IFC Industry Foundation Class STEP/XML Files (IFC) Reader/Writer
IFC_API Industry Foundation Classes (IFC) (Tech Preview) Reader
IFF 1Spatial Internal Feature Format (IFF) Reader/Writer
IGDS Bentley MicroStation Design (V7) Reader/Writer
IMDF Indoor Mapping Data Format (IMDF) Reader/Writer
IMX Autodesk IMX (FDO) Writer
INDOORGML Indoor GML Reader/Writer
INFORMIX_JDBC IBM Informix (JDBC) Reader/Writer
INFX IBM Informix Non-Spatial Reader/Writer
INFXSPATIAL IBM Informix Spatial Reader/Writer
INSPIRE INSPIRE GML Reader/Writer
ISCE Interferometric synthetic aperture radar Scientific Computing Environment (ISCE) Reader/Writer
ISO8211 ISO8211 Reader
IUF Land Victoria Incremental Update Format (IUF) Reader
JDBC Java Database Connectivity (JDBC) Reader/Writer
JOBXML Trimble JobXML Reader
JPEG Joint Photographic Experts Group (JPEG) Reader/Writer
JSON JavaScript Object Notation (JSON) Reader/Writer
KF85 Swedish KF85 Reader/Writer
KOMMUNGML KommunGML (Sweden) Reader
KUNTAGML KuntaGML (Finland) Reader
LANDONLINE Landonline (Land Information New Zealand Cadastre Survey Data Exchange Format based on LandXML) Reader
LANDSAT8 Landsat-8 Reader
LANDSAT8AWS Landsat-8 on AWS Reader
LANDXML LandXML Reader
LAS ASPRS Lidar Data Exchange Format (LAS) Reader/Writer
LOCATION_JSON Location JSON Reader
MASIK Swedish MASIK Reader/Writer
MBTILES Mapbox MBTiles Reader/Writer
MBTILES_MVT Mapbox MBTiles Vector Tiles (MVT) Reader/Writer
MCF STAR-APIC Mercator MCF Reader/Writer
MDB_ADO Microsoft Access Reader/Writer
MGE Intergraph MGE Reader/Writer
MIF MapInfo MIF/MID Reader/Writer
MINECRAFT Mojang Minecraft Reader/Writer
MITAB MapInfo TAB (MITAB) Reader/Writer
MONGODB3 MongoDB Reader/Writer
MRF Meta Raster Format (MRF) Reader/Writer
MRF_NATIVE Precisely Multi-Resolution Raster (MRR) Reader/Writer
MRSID Extensis MrSID Reader
MSACCESS_JDBC_2 Microsoft Access (JDBC) Reader/Writer
MSSQL_JDBC_AZURE Microsoft Azure Microsoft Azure SQL Database (JDBC MSSQL) Reader/Writer
MSWORD Microsoft Word Writer
MTKGML NLSF Topographic GML (MTKGML) Reader
MVT Mapbox Vector Tile (MVT) Reader
MVT_TILESET Mapbox Vector Tile (MVT) Tileset Reader/Writer
MYSQL MariaDB (MySQL compatible) Spatial Reader/Writer
MYSQL_AURORA_NONSPATIAL Amazon Aurora Non-Spatial Reader/Writer
MYSQL_AURORA_SPATIAL Amazon Aurora Spatial Reader/Writer
MYSQL_DATABASE MariaDB/SkySQL (MySQL-compatible) Reader/Writer
MYSQL_DB MariaDB (MySQL compatible) Non-Spatial Reader/Writer
MYSQL_GOOGLE Google Cloud SQL Spatial Reader/Writer
MYSQL_GOOGLE_DB Google Cloud SQL Non-Spatial Reader/Writer
NAS German AAA GML Exchange Format (NAS) Reader
NDGEOJSON NDGeoJSON (Newline Delimited GeoJSON) Reader/Writer
NDJSON NDJSON (Newline Delimited JSON) Reader/Writer
NEN3610 NEN 3610 (GML) Reader
NETCDF NetCDF (Network Common Data Form) Reader/Writer
NGRID MapInfo Vertical Mapper Grid (NGrid) Reader/Writer
NIFTI NITFI (Neuroimaging Informatics Technology Initiative) Reader/Writer
NITF National Imagery Transmission Format Reader/Writer (JITC uncertified)
NMEA_GPS NMEA GPS Reader
NTF OS (GB) NTF Reader
NULL NULL (Nothing) Reader/Writer
OBJ Wavefront OBJ Reader/Writer
ODATA OData Reader
ODBC2 ODBC 3.x Reader/Writer
OGCAPI_FEATURES OGC API - Features (WFS 3.0) Reader
OGCGEOPACKAGE OGC GeoPackage Reader/Writer
OGCKML Google Earth KML Reader/Writer
OGC_CSW OGC CSW - (Catalogue Service for the Web) Reader/Writer
OGDI Microsoft OGDI Data Lab Reader/Writer
OGEOSMS OGC Open GeoSMS Reader
OPENFILEGDB Esri Geodatabase (OpenFile Geodb) Reader/Writer
OPENFLIGHT Presagis .flt (OPENFLIGHT) Reader/Writer
OPENJPEG OpenJPEG JPEG 2000 Reader/Writer
ORACLEPOINTCLOUD Oracle Spatial Point Cloud Reader/Writer
ORACLERASTER Oracle Spatial GeoRaster Reader/Writer
ORACLE_AUTONOMOUS Oracle Autonomous Reader/Writer
ORACLE_DATABASE Oracle Database Reader/Writer
ORACLE_RELATIONAL Oracle Spatial Relational Reader/Writer
OSG OpenSceneGraphic OSGB/OSGT Reader/Writer
OSM OpenStreetMap (OSM) XML Reader/Writer
OSMASTERMAP_WATER_NETWORK_GML UK OS MasterMap Water Network (GML) Reader/Writer
OSMPBF OpenStreetMap (OSM) Protocolbuffer Binary Format (PBF) Reader
OSVECTORMAPDISTRICT OS VectorMap District Reader
OSVECTORMAPLOCAL OS VectorMap Local Reader
OS_MASTERMAP_GREENSPACE_GML UK OS MasterMap Greenspace Layer (GML) Reader/Writer
OS_MASTERMAP_HIGHWAYS_NETWORK_GML UK OS MasterMap Highways Network (GML) Reader/Writer
OS_MASTERMAP_SITES_GML UK OS MasterMap Sites Layer (GML) Reader/Writer
OS_MASTERMAP_TOPOGRAPHY_GML UK OS MasterMap Topograpy Layer (GML) Reader/Writer
P190 PGP P1/90 Post Plot Positioning Data Reader/Writer
PARQUET Apache Parquet Reader/Writer
PARQUET_DIR Apache Parquet (Partitioned) Reader
PATH Directory or File Pathnames Reader
PCARCINFO Esri PC ArcInfo Coverage Reader
PCD Point Cloud Data (PCD) Reader/Writer
PCIDSK PCI Geomatics Database File (PCIDSK) Reader/Writer
PDF Adobe 3D PDF Writer
PDF2D Adobe Geospatial PDF Reader/Writer
PERSONAL_GEODATABASE Esri Geodatabase (Personal Geodb) Reader
PLANETBASEMAPS Planet Basemaps (Tech Preview) Reader
PLANETDATA Planet Data Reader
PMTILES PMTiles Reader/Writer
PNG PNG Rasterizer Writer
PNGRASTER Portable Network Graphic (PNG) Reader/Writer
POINTCLOUDXYZ Point Cloud XYZ Reader/Writer
POSTGIS PostGIS Reader/Writer
POSTGISRASTER PostGIS Raster Reader/Writer
POSTGRES PostgreSQL Reader/Writer
POWERPOINT Microsoft PowerPoint Writer
PROTOBUF Protocol Buffers Reader/Writer
PRC Adobe Product Representation Compact (PRC) Writer
QLF CITS Data Transfer Format (QLF) Reader/Writer
QLIKCONNECTOR Qlik Connector Reader
QUBICLEBINARY Qubicle Binary Voxel File (QB) Reader
QVX Qlik data eXchange Writer
RADARSAT2 RADARSAT-2 XML Reader
RDATA R Statistical Data (RDATA) Non-Spatial Reader/Writer
RDATARASTER R Statistical Data (RDATA) Array as Raster Reader/Writer
RDB RIEGL Laser Scan Database (RDB) Reader
RDB_PROJECT RIEGL RDB Project Reader
REDSHIFT Amazon Redshift Reader/Writer
REDSHIFT_SPATIAL Amazon Redshift (Spatial) Reader/Writer
REGIS Regional Geographic Information System (REGIS) Reader/Writer
REVIT IFC with Data Views Reader
REVITNATIVE Autodesk Revit Reader/Writer
RRASTER R Statistical Raster Data (RRASTER) .grd Reader/Writer
S57 S-57 (ENC) Hydrographic Data Reader
SAFE SOCRATA.SOCRATA2 Socrata Reader/Writer YES
SAFE SOCRATA.SOCRATA2 Tyler Data & Insight Reader/Writer YES
SAFE.AIRTABLE.AIRTABLE Airtable Reader/Writer YES
SAFE.CKAN.CKANDATASTORE CKAN DataStore Reader/Writer YES
SAFE.DOCUMENTPDF.DOCUMENTPDF Document PDF Writer YES
SAFE.ESRI-AGOL.ARCGISFEATURESERVICE Esri ArcGIS Feature Service Reader/Writer YES
SAFE.GOOGLE-SHEETS.gOOGLESHEETS4 Google Sheets v4 Reader/Writer YES
SAFE.NEO4J.NEO4J nEO4J Reader YES
SAFE.STAC.STAC.ASSET STAC Asset Reader YES
SAFE.STAC.STAC.METADATA STAC Metadata Reader YES
SAFE.UNFOLDED.UNFOLDEDDATA Foursquare studio Data Reader/Writer YES
SAIF Spatial Archive and Interchange Format (SAIF) Reader
SALESFORCE Salesforce Reader/Writer
SAP_HANA__CLOUD SAP Hana Cloud Reader
SAP_HANA SAP HANA Reader/Writer
SAP_SYBASE_ASE SAP Sybase ASE Reader/Writer
SAS Statistical Analysis System (SAS) Reader/Writer
SAV IBM PASW (SPSS) .sav Reader/Writer
SCHEMA Schema (Any Format) Reader
SCHEMA_FROM_TABLE Schema (From Table) Reader
SDF3 Autodesk MapGuide Enterprise SDF Reader/Writer
SDL Autodesk MapGuide SDL Reader/Writer
SDTS Spatial Data Transfer Standard (SDTS) Reader
SEABEDML SeabedML (GML) Reader/Writer
SEG-P1 SEG-P1 Reader
SEGY SEG-Y Reader/Writer
SENTINEL1 Sentinel-1 SAR SAFE Reader
SENTINEL2 Sentinel-2 MSI SAFE Reader
SENTINEL2AWS Sentinel-2 on AWS Reader
SGI SGI IMAGE Reader/Writer
SHAPEFILE Esri Shape Reader/Writer
SHAREPOINT Microsoft SharePoint Reader/Writer
SIMPLECUSTOMFORMAT SimpleCustomFormat Reader
SKP Trimble SketchUp Reader/Writer
SLF Standard Linear Format (SLF) Reader
SNOWFLAKE Snowflake Reader/Writer
SOSI_GML SOSI GML Reader/Writer
SPATIALITE_NATIVE SpatiaLite Reader/Writer
SQLITE3 SQLite Non-Spatial Reader/Writer
SQLLDR Oracle SQL Loader Writer
SQLSERVER Microsoft SQL Server Server (MSSQL) Reader/Writer
SQLSERVER_AZURE Microsoft Azure SQL Database (MSSQL) Reader/Writer
SQLSERVER_JDBC Microsoft SQL Server (JDBC MSSQL) Reader/Writer
SRTMHGT Shuttle Radar Topography Mission Height (SRTM HGT) Reader
STL Standard Triangle/Tesselation Language (STL) Reader/Writer
STRUMAP Northgate StruMap Reader/Writer
SUNRASTER Sun Raster Reader/Writer
SURFERBINARY Golden Software Surfer Binary Grid Reader/Writer
SVG Scalable Vector Graphics (SVG) Writer
SXF Panorama Storage and eXchange Format (SXF) Reader
SYNAPSE_SQL_JDBC Microsoft Azure Synapse SQL (Data Warehouse) Reader/Writer
TARGA Truevision TGA (TARGA) Reader
TERADATA_JDBC Teradata Reader/Writer
TERRAINTILESAWS Terrain Tiles on AWS Reader
TERRASCAN Terrasolid TerraScan Reader/Writer
TEST_DELETE test_delete Reader
TETGEN TetGen Reader/Writer
TEXTLINE Text File Reader/Writer
TIFF Tagged Image File Format (TIFF) Reader/Writer
TIGER U.S. Census Bureau TIGER/Line Reader
TIGERGML U.S. Census Bureau TIGER/GML Reader
TOMTOM_POI TomTom POI Reader/Writer
TOP10 Dutch TOP10 GML Reader/Writer
TOP50NL Dutch TOP50NL GML Reader
TOPOJSON TOPOJSON (Topology JavaScript Object Notation) Reader/Writer
UDATASMITH Epic Games Unreal Datasmith Writer
UFO Danish UFO Reader/Writer
USD Pixar USD (Universal Scene Description) Writer
USGS_DEM U.S. Geological Survey Digital Elevation Model (USGSDEM) Reader/Writer
VML Vector Markup Language (VML) Writer
VPF_DB Vector Product Format Database (VPF_DB) Reader
VRT OGR Virtual Dataset (VRT) Reader
VRT_RASTER VRT Raster (GDAL Virtual Format) Reader
WCS WCS (Web Coverage Service Reader
WEBP Google WebP Reader/Writer
WFS Web Feature Service (WFS) Reader
WHITESTAR Halliburton GeoGraphix CDF Reader/Writer
WKB OGC Well Known Binary (WKB) Reader
WKT OGC Well Known Text (WKT) Reader
WLAS Well Log Ascii Standard Reader
WMS WMS (Web Map Service) Reader
WMTS WMS (Web Map Tile Service) Reader
X3D X3D Writer
X3D_VRML Virtual Reality Modeling Language (VRML) Writer
XDK XDK (XML format for Danish DSFL) Reader
XLSXR Microsoft Excel Reader
XLSXW Microsoft Excel Writer
XML Extensible Markup Language (XML) Reader/Writer
XPM X11 Pixmap (XPM) Reader/Writer
XSD_DRIVEN_XML XSD-Driven XML Reader/Writer
XYZ Space Delimited XYZ Reader
ZARR Raster Reader/Writer
ZFS Z+F LaserControl ZFS Reader
ZGF Landmark Zycor Graphics File (ZGF) Reader
ZMAP Landmark Z-Map (ASCII) Writer
ZMAPRASTER Landmark Z-Map Grid Reader/Writer
ZMAPRAW Landmark Z-Map Vector Reader
