Privileges for using ArcGIS with cloud data warehouses
In ArcGIS, you can view and analyze data from cloud data warehouses. Use the tools available through your cloud data warehouse provider to grant the privileges required to access the data. The credentials you use to connect to a cloud data warehouse from ArcGIS only need to allow the connecting user to select data.
Amazon Redshift
The connecting user requires usage privileges on the schema that contains the data they need to access and select privileges on specific tables in the schema.
To publish a feature layer that references data in Redshift, users must be granted the privilege to create views. Users who need to create a materialized view in a query layer or while publishing additionally require the privilege to create a materialized view. See the Amazon Redshift documentation for specific privileges.
To enable feature binning on a table in Redshift, you must be the table owner. You also must have the privileges to create tables and execute functions on the schema where the table is stored.
Google BigQuery
The account you use to connect must be a member of a role that has the following privileges:
  • bigquery.datasets.get
  • bigquery.jobs.create
  • bigquery.readsessions.create
  • bigquery.readsessions.getData
  • bigquery.routines.get
  • bigquery.routines.list
  • bigquery.tables.create
  • bigquery.tables.delete
  • bigquery.tables.get
  • bigquery.tables.getData
  • bigquery.tables.list
  • bigquery.tables.update
  • bigquery.tables.updateData
  • resourcemanager.projects.get
In addition, to enable feature binning on a table, the connecting account must have write access to the dataset where the table is stored.
Snowflake
To access data in Snowflake, the connecting user must have usage privileges on the schema that contains the data they need to access and select privileges on specific tables in the schema.
To enable feature binning and disable feature binning, the connecting user must have ownership privileges on the table. The connecting user must also have privileges to create tables, because a table is created in Snowflake to store the bin caches.
To allow other users to access cached feature bins, you must grant select privileges on the cache table. The table name is esri_gh__<the name of the table on which you enabled feature binning>_<srid of the table>.
To publish a feature layer that references data in Snowflake, users must be granted the privilege to create views. Users who need to create a materialized view in a query layer or while publishing additionally require the privilege to create a materialized view.
See the Snowflake documentation for specific privileges and how to grant them.
