Rename a table
You can rename a table (nonspatial or spatial, also referred to as a feature class) in a database or geodatabase using ArcGIS Pro by right-clicking it, clicking Rename, typing a new name, and pressing Enter.
The following conditions apply:
If the table is in a relational database or enterprise geodatabase, you must connect as the table owner to rename it.
You cannot rename tables that are stored in cloud data warehouses or document databases.
IBM Db2 does not allow tables to be renamed if the tables have a referential constraint defined on them.
You cannot rename tables in SQLite if the database is configured to use SpatiaLite to store geometries.
You cannot rename a table if someone else holds a lock on that table.
Do not use third-party software, such as an SQL client, to rename a table in a geodatabase, because it does not update the table name in the geodatabase system tables.
Follow the steps below to rename a table from ArcGIS Pro:
In the Catalog pane, connect to the geodatabase or database.
Right-click the table or feature class and click Rename.
The name is highlighted.
Provide a new name.
Names must start with a letter and cannot exceed the maximum number of characters the database or data warehouse allows for the table names.
Press the Enter key.
