Change the input coordinate display
You can change the display of input coordinates.
To change the display of input coordinates, complete the following steps:
  1. On the ribbon, click the Insert tab.
  2. In the Measurements group, click Distance and Direction .
  3. In the Distance and Direction pane, click the Line, Circle, Ellipse, or Rings tab.
  4. Click the Edit Properties button .
    The Edit Properties window appears.
  5. Click the Display Coordinate drop-down list and select a display coordinate format.
  6. Click OK.
  7. Click Map Point Tool and select a location on the map.
    The input box displays the selected coordinate format.
