Create circles
You can create circles interactively, from known center point and size, or based on a center point and travel rate and time.
Create circles interactively
To create circles interactively by clicking the map, complete the following steps:
  1. On the ribbon, click the Insert tab.
  2. In the Measurements group, click Distance and Direction .
  3. In the Distance and Direction pane, click the Circle tab.
  4. Click Map Point Tool .
  5. Click a location on the map to designate the center point of the circle.
  6. Optionally, choose a unit of measurement from the drop-down menu.
  7. Click a location on the map to designate the outer edge of the circle.
    A circle is created and added to the map.
Create circles from known coordinates
To create circles using known coordinates and a known radius or diameter, complete the following steps:
  1. In the Distance and Direction pane, click the Circle tab.
  2. Enter a coordinate in the Center Point text box.
  3. Enter a distance in the Radius/Diameter text box.
  4. Press Enter or click Create Circle.
Create circles using a time and speed
To create circles to identify potential locations for moving objects using a center point, time, and speed, complete the following steps:
  2. Enter a coordinate in the Center Point text box or click Map Point Tool and click a location on the map.
  3. Expand Distance Calculator.
  4. Enter a rate of time in the Time text box.
  5. Enter a rate of travel in the Rate text box.
  6. Press Enter or click Create Circle.
Change tool units
You can change the units the tool uses to display and label outputs.
  • Use the Radius/Diameter drop-down list to change the unit of measure.
  • Use the Time drop-down list to change the unit of time.
  • Use the Rate drop-down list to change the unit of measure.
Distance and Direction feature classes are labeled according to fields that are populated at the time of feature creation. Changing the geometry of the feature with editing tools does not update the labels. To update labels, you must change the values stored in the attribute table or re-create the feature.
Measure circles
The From drop-down list provides the following circle measuring options:
Option
Radius
The circle is measured and labeled with a radius value.
Diameter
The circle is measured and labeled with a diameter value.
