Create ellipses
You can create ellipses interactively or from known coordinates.
Create ellipses interactively
To interactively create an ellipse by clicking on the map, complete the following steps:
On the ribbon, click the Insert tab.
In the Measurements group, click Distance and Direction
.In the Distance and Direction pane, click the Ellipse tab.
Click Map Point Tool
.Click a location on the map to designate the center point of the ellipse.
Click a location on the map to designate the vertex of the major axis.
The direction you move the pointer from the center point to the vertex of the major axis designates the ellipse orientation.
Click a location on the map to designate the vertex of the minor axis.
An ellipse is created and added to the map.
Create ellipses from known values
To create an ellipse using known coordinates, complete the following steps:
Type or paste a coordinate in the Center Point text box.
Type a value in the Major text box.
Type a value in the Minor text box.
Type a value in the Angle text box.
Press Enter or click Create Ellipse.
Change tool units
You can change the units the tool uses to display and label outputs. Use the Units drop-down list to change the units of measure.
Distance and Direction feature classes are labeled according to fields that are populated at the time of feature creation. Changing the geometry of the feature with editing tools does not update the labels. To update labels, you must change the values stored in the attribute table or re-create the feature.
Ellipse type
The Ellipse Type drop-down list provides the following ellipse measuring options:
Option |
Description |
Semi |
The ellipse is drawn and measured using the supplied values as one half of the major axis and one half of the minor axis. |
Full |
The ellipse is drawn and measured using the supplied values as the full major axis and the full minor axis. |
