Create sectors
You can create range fans, wedges, and arcs interactively or from known center point, minimum and maximum distances, and horizontal start and end angles. Wedges are a special case of range fans that begin at the center point.
Create range fans interactively
To create range fans interactively by clicking the map, complete the following steps:
On the ribbon, click the Insert tab.
In the Measurements group, click Distance and Direction
.In the Distance and Direction pane, click the Sector tab.
Under Type, click Fan.
Click Map Point Tool
.Click a location on the map to designate the starting point of the range fan.
Optionally, choose a unit of measure from the Units drop-down menu.
Optionally, choose an angle unit from the Angle drop-down menu.
Click a location on the map to designate the minimum distance and horizontal start angle.
Click a location on the map to designate the maximum distance and horizontal end angle.
A range fan is created and added to the map.
Create range fans from known coordinates
To create range fans using known coordinates, minimum and maximum distances, and horizontal start and end angles, complete the following steps:
Provide a coordinate in the Starting Point text box.
Provide a distance in the Minimum Distance text box.
Provide a distance in the Maximum Distance text box.
Provide an angle in the Horizontal Start Angle text box.
Provide an angle in the Horizontal End Angle text box.
Press Enter or click Create Sector.
Create wedges interactively
To create wedges interactively by clicking the map, complete the following steps:
Under Type, click Wedge.
.Click a location on the map to designate the starting point of the wedge.
Click a location on the map to designate the distance and horizontal start angle.
Click a location on the map to designate the horizontal end angle.
A wedge is created and added to the map.
Create wedges from known coordinates
To create wedges using known coordinates, minimum and maximum distances, and horizontal start and end angles, complete the following steps:
Create arcs interactively
To create arcs interactively by clicking the map, complete the following steps:
Under Type, click Arc.
.Click a location on the map to designate the base point of the arc.
An arc is created and added to the map.
Create arcs from known coordinates
To create arcs using known coordinates, a maximum distance, and horizontal start and end angles, complete the following steps:
