Export or remove results
You can export or remove results created with Distance and Direction.
To export or remove results, complete the following steps:
On the ribbon, click the Insert tab.
In the Measurements group, click Distance and Direction
.In the Distance and Direction pane, click the Line, Circle, Ellipse, Rings, or Sector tab.
Click Export to export the results to a file geodatabase, shapefile, or
.kmzfile.Click Clear All to remove the results from the map and geodatabase.
