Tutorial: Find addresses
In this tutorial, you'll learn how to find addresses or places in the Locate pane using the ArcGIS World Geocoding Service and a locator on disk.
Get the data
The data for this tutorial is available for download.
  1. Go to the data download page.
  2. Click the Download button, and save the file locally.
  3. Unzip the downloaded file.
Find an address or place on the Locate pane using the ArcGIS World Geocoding Service
  1. Open ArcGIS Pro.
  2. Sign on to ArcGIS Online.
  3. Create a blank project. On the start page, click Start without a template.
  4. On the Insert tab, click New Map .
    A basemap appears.
  5. On the Map tab, in the Inquiry group, click the Locate button .
    The Locate pane appears.
  6. On the Locate pane, type 10 E Main St, Madison, WI in the search box.
    As you type, a list of suggested results displays.
  7. Click the first item on the list.
    One or more match results display, and each is prefixed with a capital case letter.
  8. Click any item on the list to view the location on the map.
    The letter symbol of the item highlights on the map.
    Tip:
    If the item is outside the current map display, right-click the candidate and click Zoom To or Pan To on the right of the selected item to zoom or pan to the location of the result on the map.
    Click the Menu button and click Zoom To All to zoom to all matched results on the map.
    Click the Menu button and click Detailed View to display the details of each match result.
    In a local area of the map (a map scale larger than 1:500000), you may search features based on a category, such as a gas station or pizza restaurant.
  9. Zoom to an area of a scale larger than 1:500000.
  10. Type pizza in the search box.
    A list of pizza restaurants on the map area are found.
    You may also find places or city names with the ArcGIS World Geocoding Service.
  11. Type London, England in the search box.
    The map automatically zooms to the location.
  12. Click the Down arrow on the search box to display the search history and select the address or place name you want to find again.
Find an address on the Locate pane using a locator on disk
Locate the Evansville.loc file you downloaded from the item description web page of the geocoding tutorial data inside the geocoding tutorial folder.
  1. Add the Evansville locator from the geocoding tutorial folder to the project.
    1. Right-click the Locators folder in the Catalog pane.
    2. Select Add Locator.
    3. Select the Evansville.loc file from the geocoding tutorial folder.
    4. Click OK.
    The Evansville locator is added to the Locators folder in the Catalog pane.
  2. On the Locate pane, type 42 Cherry Avenue, Evansville IN in the search box.
    Match results from both ArcGIS World Geocoding Service and the Evansville locator display.
  3. Click the first candidate of the Evansville locator, right-click the candidate, then select Zoom To to zoom to the match location on the map.
