Mobile geodatabase size and name limits
Mobile geodatabase size and name limits are as follows:
Mobile geodatabase size—2 TB database limit
Table or feature class size—No limit within the 2 TB database limit
Tip:
SQLite is a self-contained database file format that stores the entire database in a single file on disk. All SQLite database objects in a mobile geodatabase, such as the geodatabase tables, indexes, triggers, and views, use some of the available space within this 2 TB limit.
Number of feature classes and tables—2,147,483,647
Number of fields in a feature class or table—2,000
Number of rows in a feature class or table—2,147,483,647
Geodatabase name length—The number of characters the operating system allows in a folder name
Since a mobile geodatabase (
.geodatabasefile) is built on top of SQLite, the name of the mobile geodatabase consists of the file path, file name, and file extension.For example, if you are using a Windows operating system, the name of this mobile geodatabase,
C:\GIS_Data\Projects\Mobile_Geodatabase\Project1_data.geodatabase, contains 65 characters.The database names
mainandtempare reserved SQLite database names.
Feature dataset name length—160 characters
Feature class or table name length—128 characters
Index name length—128 characters
Field name length—128 characters
Text field width—1,000,000,000 bytes
Domain name length—257 characters
Attribute Rule
Name—64 characters
Description—256 characters
