Update open_cursors setting in geodatabases in Oracle
By default, the geodatabase uses an Oracle open_cursors setting of 300. The geodatabase does not have access to the open_cursors value set for the Oracle database; therefore, if you set your Oracle database open_cursors parameter to a value other than 300, run the sde.gdb_util.update_open_cursors stored procedure to synchronize the geodatabase's open_cursors setting with that of the Oracle database in which it is stored.
If you do not synchronize the open_cursors setting between the Oracle database and the geodatabase, activities that require multiple cursors could fail.
The sde.gdb_util.update_open_cursors stored procedure is present in the geodatabase. Follow these steps to synchronize the open_cursors setting using the stored procedure:
Connect from an SQL client to the geodatabase using sys as sysdba.
Grant privileges to the sde user to run the
sde.gdb_util.update_open_cursorsstored procedure.GRANT INHERIT PRIVILEGES ON USER SYS TO SDE;Run the
sde.gdb_util.update_open_cursorsstored procedure.EXECUTE sde.gdb_util.update_open_cursors;You can revoke the
inheritprivilege you granted to the sde user in step 2.REVOKE INHERIT PRIVILEGES ON USER SYS FROM SDE;
The database and geodatabase open_cursors settings are now synchronized.
If you update the Oracle open_cursors setting in the database in future, run this stored procedure again to update the setting in the geodatabase.
