Enterprise geodatabase size and name limits
Limits on the size of database objects in an enterprise geodatabase are mostly dependent on hardware limitations. The limit on database object name size is the smaller of either the limit enforced by the database management system or the geodatabase limit. Limits vary from one database management system to the next. The types of characters allowed in object names vary by database management system but are also affected by how ArcGIS stores and queries the object information.
Size limits
Most size limits in a database depend on the database management system edition and hardware limitations. See the documentation for your database management system to determine size limits.
Number of characters in object names
The following table lists the maximum number of characters allowed by ArcGIS for each type of object name:
Object type
Maximum bytes allowed by ArcGIS
Database name
ArcGIS does not create databases for SAP HANA but can read database names of up to the SAP HANA limit.
Table, feature class, view, full-text index, or attribute index name
Up to the database management system's limit.
Field (column) name
Password
256 when reading passwords, 31 when creating passwords
User or role name
Character type limits in object names
Database management systems have different definitions of acceptable characters for object names. Most allow you to use unacceptable characters if you provide the object name enclosed in delimiters, such as double quotation marks.
However, ArcGIS does not add delimiters when querying objects in the database. Do not create any tables, feature classes, indexes, databases, users, roles, or other object names that require delimiters if you will use them in ArcGIS. The object will be created in the database, but you cannot access it from ArcGIS.
Similarly, delimiters are not added when you create database objects, such as a table or database, from ArcGIS. If the name you provide when you create the object uses character casing that the database does not support unless the text is inside delimiters, the underlying database changes the casing. The next time you attempt to access the object from ArcGIS, you may receive an error message indicating that the object does not exist.
Number of characters in nonobject names
Enterprise geodatabase functionality provides constructs that appear to be database objects when viewed in ArcGIS Pro but are actually values in geodatabase system tables. The names of these constructs also have character limits. Examples of these are listed in the table below.
Geodatabase construct type
Domain name
257
Feature dataset name
159
Field alias
255
Version name
62
