Data migration from one storage type to another
You can use the Migrate Storage geoprocessing tool to migrate existing binary spatial columns from one storage type to another. This is done by specifying a configuration keyword that contains a GEOMETRY_STORAGE parameter set to the new storage type to which you want to convert. You can also use the Migrate Storage geoprocessing tool to change the storage format of geometry attributes for parametric objects and surface patches in geodatabases in Microsoft SQL Server.
It is important to create the configuration keyword to include the correct parameter and value. Create a custom configuration keyword specifically for the migration. Ensure that the keyword contains the parameter and value to which you are migrating the data, as well as a UI_TEXT parameter. The UI_TEXT parameter makes the keyword available to ArcGIS clients. Provide this keyword to the dataset owners, as they are the ones who must run the Migrate Storage geoprocessing tool.
The following are the supported migration paths for geodatabases in SQL Server:
Configuration parameter
Migrate from/to
GEOMETRY_STORAGE
SDEBINARY to Geometry
SDEBINARY to Geography
OGCWKB to Geometry
OGCWKB to Geography
Geometry attributes stored in a related system table to geometry attributes stored in a column in the base table
Tip:
If the table being migrated is registered to participate in traditional versioning, migrating it to a different storage type also updates the corresponding columns in the Adds table. If the feature class has archiving enabled, the archive table's columns are also updated.
When to migrate data
The following are reasons to migrate data:
  • To access spatial or raster data using structured query language (SQL)
  • To move from a data type that may not be supported in the future to one that is supported
  • To move geometry attribute information from a side table in SQL Server to a column in the base table to improve performance in parcel fabrics and to allow you to register the feature class for branch versioning.
Access data using SQL
Accessing the information in a geodatabase using SQL allows external applications (those not developed in an ArcObjects environment) to work with the data managed by the geodatabase. If these applications need to access spatial or raster data in the geodatabase, you must use data types that allow SQL access. For example, using the Geometry storage type allows you to access your feature data with SQL, something that you cannot do easily if your data is stored in a binary field.
Move from types that may not be supported in future releases
Feature classes created in ArcGIS 10.1 and later geodatabases in SQL Server use the Microsoft Geometry type by default. To move existing feature classes to the Geometry storage type, use the Migrate Storage geoprocessing tool or a Python script.
Move geometry attributes to improve performance
If you have feature classes that participate in parcel fabrics or store true curves, multipatches, or pointIDs, and these were created using ArcGIS 10.4 or ArcGIS Pro 1.3 or earlier, consider migrating storage for these geometry attributes. Supported migration paths for existing feature classes are as follows:
  • The storage type is Microsoft Geometry and you want to continue using the Geometry type.
    To migrate the geometry attributes from the related table to a new column in the feature class's business table, specify a configuration keyword that has the GEOMETRY_STORAGE parameter set to GEOMETRY, and run the Migrate Storage tool.
  • The storage type is Microsoft Geography and you want to continue using the GEOGRAPHY type.
    To migrate the geometry attributes from the related table to a new column in the feature class's business table, specify a configuration keyword that has the GEOMETRY_STORAGE parameter set to GEOGRAPHY, and run the Migrate Storage tool.
  • The storage type is SDEBINARY and you want to migrate to the Microsoft Geometry type.
    To do this, specify a configuration keyword that has the GEOMETRY_STORAGE parameter set to GEOMETRY, and run the Migrate Storage tool. This migrates both the spatial data type and geometry attributes to the new storage format.
    • Storage type is SDEBINARY and you want to migrate to the Geography type.
    In this case, specify a configuration keyword that has the GEOMETRY_STORAGE parameter set to GEOGRAPHY, and run the Migrate Storage tool. This migrates both the spatial data type and geometry attributes to the new storage format.
Migration prerequisites
The following conditions must be met before you can convert the data:
  • Make a backup of the data before you migrate it.
  • The table or feature class must be registered with the geodatabase.
  • You must connect to the geodatabase as the owner of the table.
  • The configuration keyword you specify when migrating the data type must contain the correct value for the GEOMETRY_STORAGE parameter. For example, to migrate an sdebinary geometry column to Geometry, specify a keyword that has the GEOMETRY_STORAGE parameter set to GEOMETRY.
  • Migration of a feature class to the SQL Server Geography type requires that the data be in one of the geographic coordinate systems supported by the Geography type.
    Tip:
    The list of supported coordinate systems that can be used with the SQL Server Geography type is in the SQL Server system view sys.spatial_reference_systems.
