Bit depth capacity for raster dataset pixels
The bit depth (pixel depth) of a pixel determines the range of values that a particular raster file can store, which is based on the formula 2n (where n is the bit depth). For example, an 8-bit raster can have 256 unique values that range from 0 to 255.
The following table shows the range of values stored for different bit depths:
Bit depth
Range of values that each cell can contain
1 bit
0 to 1
2 bit
0 to 3
4 bit
0 to 15
Unsigned 8 bit
0 to 255
Signed 8 bit
-128 to 127
Unsigned 16 bit
0 to 65535
Signed 16 bit
-32768 to 32767
Unsigned 32 bit
0 to 4294967295
Signed 32 bit
-2147483648 to 2147483647
Floating-point 32 bit
-3.402823466e+38 to 3.402823466e+38
Unsigned 64 bit
0 to 18446744073709551616
Range of values by pixel depth
An additional type of bit depth, called complex, is supported for reading and displaying purposes. This bit depth exists in a number of raster formats, including radar formats such as Radarsat, and .gff.
There are exceptions when the true bit depth does not match the bit depth property within Raster Properties. While the Esri Grid rasters are always stored with a 32-bit depth (either as signed integer, unsigned integer, or floating point), ArcGIS will display the bit depth property with the most appropriate bit depth according to the range of pixel values the raster contains.
Esri products contain all the designations of unknown values within their raster datasets. The unknown values are NoData. Internally, a real value must be used to store the NoData pixels. Accordingly, when NoData is added to a raster that already has a full bit range (meaning that there is at least one pixel in the raster extent occupying all the values in the bit range, for example, when 0 to 255 are all represented), it is promoted to the next higher bit depth. For example, a hillshade grid with cell values of 0 to 255 (which would otherwise fit within the 8 bit range), that also contains some NoData cells, is represented as unsigned 16 bit.
