Create ortho mapping products using the custom wizard
Available with the Advanced license.
Available with a Standard license and the Reality Mapping user extension.
The Custom Products wizard provides a flexible guided workflow for creating ortho mapping products. For example, you can create a digital elevation model (DEM) and an orthomosaic at the same time using the Custom Products wizard. You can also generate a mosaic by disabling steps that are not needed for your workflow, such as turning off color balancing if the image colors are already homogeneous.
Product Generation Settings page
The Product Generation Settings page allows you to specify the ortho mapping products you want to create. The wizard allows you to create a DEM, an orthomosaic, or both. Check the boxes for the products you want to create. Each ortho mapping product also has parameters to perform specific tasks during its creation. The following table lists the options on the Product Generation Settings page:
Option |
Description |
Digital Elevation Model |
Check this box to create a DEM ortho product. You need to complete the parameters on the Point Cloud Settings page. If you do not check the Interpolate DEM from Solution Points check box, you also need to complete the options on the DEM Interpolation Settings page. |
Interpolate DEM from Solution Points |
Check this box to create a DEM by interpolating from solution points. When you check this box, you only need to complete the parameters on the Point Cloud Settings page. |
Orthomosaic |
Check this box to create an orthomosaic product. |
Generate Seamlines |
Check this box to build seamlines during the orthomosaic creation. If you choose to build seamlines, you need to complete the parameters on the Seamline Settings page. |
Color Balance |
Check this box to color balance the image collection during the orthomosaic creation. If you choose to color balance, you need to complete the parameters on the Color Balance Settings page. |
Generate Orthomosaic |
Check this box to create a raster dataset output for the orthomosaic. If you choose this option, you need to complete the parameters on the Orthomosaic Settings page. |
The following table lists the parameters on the Point Cloud Settings page:
Parameters for Point Cloud Settings
Parameter |
Description |
Matching Method |
Specifies the matching method that will be used to generate a point cloud:
Maximum Object Size to Filter (in meters) |
A search radius that is used to filter out objects above ground. Objects smaller than the threshold are filtered as ground; otherwise, objects are treated as above-ground features such as buildings, bridges, or trees. |
Point Ground Spacing (in meters) |
The spacing, in meters, at which the 3D points are generated. The suggested spacing is five times the source image pixel size. |
Minimum Intersection Angle (in degrees) |
The point cloud is generated from stereo pairs. This value defines the minimum angle the stereo pair must meet. The default is 5 degrees. A stereo pair with an intersection angle that is too small will produce unstable results when triangulating 3D points. |
Maximum Intersection Angle (in degrees) |
The point cloud is generated from stereo pairs. This value defines the maximum angle the stereo pair must meet. The default is 70 degrees. A stereo pair with an intersection angle that is too large will produce few or no match points. |
Minimum Area Overlap |
The percentage of overlapping area over the entire image. The default is 0.6. |
Advanced Options |
Maximum Omega/Phi Difference (in degrees) |
The maximum threshold for the Omega and Phi difference between the two image pairs. The Omega values and Phi values for the image pairs are compared. If the difference between either the two Omega or the two Phi values is above the threshold, the pairs will not be formatted as a stereo pair. |
Maximum GSD Difference |
The threshold for the maximum ground sample distance (GSD) between two images in a stereo pair. If the resolution ratio between the two images is greater than the threshold value, the pairs will not be built as a stereo pair. The default value is 2. |
Number of Image Pairs |
The number of pairs used to generate 3D points. For a project that has dense overlaps and many stereo pairs, increasing this number means more computation time. The suggested value is 8. Sometimes a location may be covered with many image pairs. In this case, the pairs will be ordered based on the various threshold parameters specified in this tool. The pairs with the highest scores will be used to generate the points. The parameters that affect the order of the stereo pair, in addition to Minimum Intersection Angle, Maximum Intersection Angle, and Minimum Area Overlap, can also include Maximum Omega/Phi Difference, Maximum GSD Difference, and Adjustment Quality Threshold. |
Adjustment Quality Threshold |
The minimum adjustment quality that is acceptable. The threshold value is compared to the adjustment quality value that is stored in the stereo model. Image pairs with an adjustment quality less than the specified threshold receive a score of 0 for this criteria and will descend in the ordered list. The values for the threshold ranges from 0 to 1. The suggested value is 0.2. |
References:
Heiko Hirschmuller et. al., "Memory Efficient Semi-Global Matching," ISPRS Annals of the Photogrammetry, Remote Sensing and Spatial Information Sciences, Volume 1-3, (2012): 371-376.
Hirschmuller, H. "Stereo Processing by Semiglobal Matching and Mutual Information." Pattern Analysis and Machine Intelligence, (2008).
The following table lists the parameters on the DEM Interpolation Settings page:
Parameters for DEM Interpolation Settings
Parameter |
Description |
Surface Type |
Specifies the surface type for a digital terrain model or a digital surface model.
Cell Size |
The pixel size for the DEM. The output pixel size should be the same or larger than the pixel size of the source image. You can provide a value to be multiplied by the Ground Sample Distance (GSD) value, which is the source pixel resolution, or you can provide an explicit value that represents the size of the pixel in units that match the source imagery. |
Format |
Specifies the format for the output raster dataset:
Compression |
Specifies the compression method for the output DEM. The following options will be available based on the Format value specified:
Interpolation Method |
Specifies the method that will be used to interpolate the output raster dataset from the point cloud.
Smoothing Method |
Specifies the filter that will be used to smooth the output raster dataset.
Fill Missing Pixels Using |
A DEM input that is used to fill NoData areas. Areas of NoData may exist where stereo overlap is insufficient or no matching points are found in the area during point cloud generation. |
Orthorectify images using DEM |
Updates the orthorectification process in the image collection. Check this parameter to orthorectify the image collection using the DEM generated using the wizard. If you don't want to replace the current elevation model with the newly generated DEM, uncheck this parameter. Check the parameter only when you are sure that the DEM output is acceptable and you do not need to generate it again. If you have another DEM to use to orthorectify the image collection, you can enter it on the Orthomosaic Settings page. |
The following table lists the parameters on the Color Balance Settings page:
Parameters for Color Balance Settings
Parameter |
Description |
Select Mosaic Candidates |
The Select Mosaic Candidates parameter is typically used for image collection with dense overlaps such as drones. It is used to find an optimum set of images that can be used when mosaicking images. The selected images will be used in seamline building, color balancing, and output mosaic operation. |
Balance Method |
Specifies the color balancing algorithm that will be used.
Color Surface Type |
If the Dodging balance method is used, each pixel needs a target color, which is determined by the surface type.
Target Raster |
The raster that will be used as a target to color balance the image collection. It can be a raster dataset, a mosaic dataset, or an image service. The statistics required by the balance method and color surface type, if applicable, will be derived from this target image. |
Recalculate Statistics |
Once color balancing has been performed, there may be new pixel values in the raster. Check the check box to calculate the statistics with the latest pixel values. |
Number of Columns to Skip |
The number of horizontal pixels that will be skipped between the samples used to calculate statistics. The value must be greater than zero and less than the number of columns in the raster. The default is 1. |
Number of Rows to Skip |
The number of vertical pixels that will be skipped between the samples used to calculate statistics. The value must be greater than zero and less than or equal to the number of rows in the raster. The default is 1. |
The following table lists the parameters on the Seamline Settings page:
Parameters for Seamline Settings
Parameter |
Description |
Computation Method |
The computation method that will be used to generate seamlines.
Advanced Options |
Pixel Size |
The pixel size that will be used for seamline generation. A mosaic dataset may contain raster items with different resolutions. Use this parameter to designate the pixel size for generating seamlines. |
Minimum Region Size |
Specify the minimum region size, in pixel units. Any polygons smaller than this specified threshold will be removed in the seamline result. The default is 100 pixels. |
Processing |
Blend Width Units |
Specifies the unit of measurement that will be used for the blend width.
Blend Width |
Blending (feathering) occurs along a seamline between pixels where there are overlapping rasters. The blend width defines how many pixels will be blended. If the blend width value is 10, and you use |
Blend Type |
Specifies the method that will be used to blend one image into another over the seamlines.
Request Size Type |
Specifies the units that will be used for the Request Size value.
Request Size |
Specify the number of columns and rows for resampling. The maximum value is 5,000. Increase or decrease this value based on the complexity of your raster data. Greater image resolution provides more detail in the raster dataset but also increases the processing time. |
Sliver Removal Options |
Minimum Thinness Ratio |
Define how thin a polygon can be, before it is considered a sliver. This is based on a scale from 0 to 1.0, where a value of 0.0 represents a polygon that is almost a straight line, and a value of 1.0 represents a polygon that is a circle. Slivers are removed when building seamlines. |
Maximum Sliver Size |
The maximum size a polygon can be to still be considered a sliver. This parameter is specified in pixels and is based on the Request Size value, not the spatial resolution of the source raster. Any polygon that is less than the square of this value is considered a sliver. Slivers are removed when building seamlines. |
The following table lists the parameters on the Orthomosaic Settings page:
Parameters for Orthomosaic Settings
Parameter |
Description |
Pixel Size |
The pixel size that will be used for the orthomosaic. |
Format |
Specifies the output format that will be used for the orthomosaic.
Compression |
Specifies the compression method that will be used for the output. The available options will be based on the Format value.
Optional |
Orthorectify Source Image Collection Using |
The digital elevation model (DEM) that will be used to orthorectify the orthomosaic. Options include the reference DEM for the workspace, a DEM generated using the DEMs Wizard, or an external DEM. |
Only Orthorectify Source Image Collection |
Specifies whether only the source image collection will be orthorectified. Checked—Only the individual images in the image collection will be orthorectified. No orthomosaic will be generated. Unchecked—An orthomosaic will be generated. |
