Georeferencing options
The georeferencing options allow you to set defaults for your georeferencing sessions. These options allow you to change symbols and their color, change the type of residuals to display in the Control Point Table, and switch the Auto Complete and Auto Apply options on and off.
To access these options, click the Options button next to Alignment on the Imagery tab.
Options
Option
From Symbol
Edit the symbol used to display the From (source) point.
From Color
Edit the color used to symbolize the From (source) point.
To Symbol
Edit the symbol used to display the To (target) point.
To Color
Edit the color used to symbolize the To (target) point.
Reset
Reset the symbol and color back to the system defaults.
Forward residual
The forward residual error for each control point is displayed in the Control Point Table.
Inverse residual
The inverse residual error for each control point is displayed in the Control Point Table.
Inverse forward residual
The inverse forward residual error for each control point is displayed in the Control Point Table.
Auto Complete
The system attempts to find the corresponding To (target) point. If the To point cannot be automatically found, you can manually specify it.
Auto Apply
Sets the default behavior for the Auto Apply button .
By default, Auto Apply is checked on.
