Mosaic Dataset Analyzer: Error 70108
Error
The TYPEID field of the mosaic dataset item is invalid.
The TYPEID field has a value that is null or less than zero. There is a chance that your footprints are corrupt.
When this error occurs, it is not possible to synchronize your mosaic dataset.
Solution
There is no easy solution to automatically fix this issue. There are two possible ways to work around this issue:
  • Edit the TYPEID field to have valid values.
  • Remove all the invalid mosaic dataset items and reload them.
